I am having problems with the catch tank set up.
I have removed the pcv,blanked off the sump entry. camcover and block entries have been tee-ed together and piped into the tank,the other pipe from the tank is just to atmosphere.
I'm getting oil coming out of the catch tank??????
It has been suggested that i use the drain plug to recirc the oil from the catch tank back into the sump which I can do, but I am worried there may some underline problem as to why there is so much pressure at the catch tank,enough to spit the oil back out!?
any ideas anyone??
JT
