Results 1 to 19 of 19
    deathrider311271's Avatar
    Apr 2011
    Grimsby
    483
    P0121 and a bang
    right guys,
    on the way home from work tonight i was accelerating fairly hard when i heard a bang, no power for about 3 seconds then limited power, car wont tick over and when it does its extremely lumpy, runs okish over 3k rpm.
    Oh and have a guess what lights are on................................................ ..
    bloody ETS and engine
    So im thinking i have managed to blow my ETM completly
    Checked all turbo hoses and appear to be fine.
    thoughts please.
    Simon
    P1 V70 2.5T Scorpion Exhaust, 3" downpipe 100cel cat, BSR induction, KKK24, GWE 3" Maf to turbo pipe,japanifold , 2010 V50 T5 Alloys Projector Headlamps with 5k Hid kit Quickshift kit, strut brace, Koni Yellow Sport,IPD BCS AET motorsport remap
    Previous: 2004 XC90 T6, 240GLT Estate, 343DL
    Toys: Capri 3.7 Twin turbo, Kawasaki ZX10R 2006,
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by deathrider311271 View Post
    right guys,
    thoughts please.
    Simon
    Slipped Timing belt??
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    The last time that sort of thing happen to me, it was a Burst Turbo hose from intercooler.
    Apr 2011
    Grimsby
    483
    Quote Originally Posted by merc85 View Post
    would that throw this code up tho??
  5. #5
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    P0121 Throttle Position Sensor/Switch A Circuit Range/Performance Problem
  6. #6
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Quote Originally Posted by p fandango View Post
    thats etm fault on a me7 tho aint it?
  7. #7
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Unhappy
    Sorry bud forgot urz is me7... searched the code came up etm fault. man you aint having any luck latly.
  8. #8
    p fandango's Avatar
    Aug 2004
    4,216
    i've no idea tbh, thats why i only posted the description. From the wording i'd of said it sounds more like the potentiometer on the pedal, as i say only a guess
  9. #9
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    I suppose the only way to go is reset the code and see if the car runs any better.
  10. #10
    Apr 2011
    Grimsby
    483
    cleared codes still runs like a bag of spanners, but also now got the code for MAF sensor not impressed with that one as its only 6 months old. Disconnected MAF and it ticks over okish, went for a run and got code p0121 again and P0102 flow too low. With MAF disconected the boost is also eratic but that may well be down to the fact the MAF is disconnected
  11. #11
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    You checked the intercooler for any leaks? i've got a 2nd hand but good maf you can borrow if you like. if thats the same as a me7 car of course.
  12. #12
    bubba_1986's Avatar
    Sep 2005
    Paisley
    137
    Me and wobbly have a maf for sale, car was running fine with it. Same one that the etm came off of
    Bubba
  13. #13
    Moderator
    happy
    shepbomb's Avatar
    Jun 2011
    Doncaster
    374
    P0121 throttle unit internal fault
    Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
    Current Car:850t5
  14. The Following User Says Thank You to shepbomb For This Useful Post:
    p fandango (Saturday 9th June 2012)
  15. #14
    Member
    May 2011
    York
    0
    Surly if you heard a bang it has to be a mechanical failure ?
  16. #15
    Apr 2011
    Grimsby
    483
    Quote Originally Posted by yorkiet52 View Post
    Nope not mechanical failure, MAF is knackered and also ETM is knackered, the bang i heard was a blowback thro the ETM which has bent the butterfly slightly.
    Good job i have a spare ETM and a MAF on the way lol
    Simon
  17. The Following User Says Thank You to deathrider311271 For This Useful Post:
    merc85 (Saturday 9th June 2012)
  18. #16
    Trader
    merc85's Avatar
    Sep 2010
    Harwich Essex
    4,987
    Thumbs up
    Simon
    Glad you got it sorted buddy, hopefully some luck going ur way.
  19. #17
    trying hard to look busy!
    jdavis's Avatar
    Dec 2008
    Doncaster, South Yorkshire
    1,050
    check the vacuum hoses at the turbo. i had a very similar problem to this on mine and the hose that is on the intake pipe, just in front of the compressor housing had come off, took me ages to find it, it was while i was swapping MAF's over that i spotted it, had probably come loose due to worn top engine mount as it was before i polybushed it. Sounds like an identical scenario, i went to boot in past a car, floored it, loud noise, lost throttle, coasted to layby, turned engine off, turned it back on all was well apart from the dreaded lights and a bit of crap running,
    I stuck it back on and ETM light went straight out and car was running spot on again. worth a look mate
    It's a 5 Cylinder Orchestra!
  20. #18
    Apr 2011
    Grimsby
    483
    Quote Originally Posted by jdavis View Post
    thanks for that, i checked all the pipes and vac pipes and they all seem fine will recheck them when i fit the new maf
    simon
  21. #19
    Vikingxl's Avatar
    Mar 2005
    Reykjavic
    656
    Mine was like this when i blew my intercooler into pieces
