hi all,
right im modifying the headlight loom to take ph2.5 headlights and was wondering if you can tell exactly the four plugs do on each side.
obviously ones is indicators, another headlight lamps..just the other 2..
hi all,
What's a phase 2.5??
What year is yer car?
If it's from 1997 - 2000 then it will be phase 1, 2 or 3.
2001 > are P26 models.
I may have madeva mistake..
Mines a2003 v70.
I'm putting a complete facelift front on it. Hence 2.5..
Apologies if I'm mistaken
Unfortunately it doesn't appear that simple..
None of the multi plugs match...
This weekend is going to be taken up by modifying the loom I think..
Im only doing it as needed some bits and its having a full respray so seemed like a good idea at the time
