Hi
I thought I'd start a fresh thread following on from the Mis-fire thread previously posted.
My OBDII DTC reader came this morning, so I've plugged it in and managed to read my own codes!
It's given me 3 fault codes (DTC's) and has even given me the meaning of them too:
P0300 - Random/Multiple Cylinder Misfire Detected
P0301 - Cylinder 1 Misfire Detected
P0302 - Cylinder 2 Misfire Detected
So, coil packs on their way out then? Or maybe blocked injectors causing random misfire?
I've cleared the DTC's and I'll drive around for a while and see if logs the same codes again. That way I'll know if it's an ongoing problem or whether it was caused by my overzealous use of fuel system cleaner.
I'll read the codes after 50 miles or so and I'll post the results on here.
By the way, if anyone is near South Powys and need their codes reading, I'll do it for free. Don't pay the garages to plug a box in to your dash.
Regards
James
