Hi
Ok, unfortunately the mis-fire/judder is back..
I was driving back from work tonight, about a mile from home I did a slight 'hill start' after giving way to a car and the car juddered and it was worse under acceleration. Also, the engine warning light came on intermittently and when I got home, I was even more worried... I could smell a bit of burning oil type smell and there was a little smoke too along with the judder, although the rpm needle wasn't going up and down too much but the engine sounded rough.
I'm really worried now, I don't know whether there is something seriously wrong with the engine or not. Why the burning oil smell and engine warning light? Yikes!
There's been no oil leaks from the engine block and the car hasn't long been serviced. I know the throttle body is the repaired Magnetti unit too thanks to the help of some of you in this forum.
If it's any help, I'd been using the cruise control on the way home tonight for a few miles so is it linked to that perhaps in some way indirectly or directly?
From the symptoms described, has anyone got any ideas as to what this could be?
Thanks for any advice....
Regards
James
