Any recommendations and best supplier?
My front pads and disks need replacing.
Do I stick with OE or change?
And how much is this going to cost!
thanks
thanks
S60 D5, 2002
BMW 545i touring
Dpends on yr budget and what u want out of it.Best value for money is brembos from GSF
Local motor factors in Devon not a national chain
got brembo pads and discs for £175 delivered.
the rears need doing too :-(
S60 D5, 2002
BMW 545i touring
Hi here are the brembo part No's and some photos as well.
BRM-09.8614.11 Single brake disc unit cost 55.00 each +vat
P5-4040 Front Pads unit cost 34.00 set +vat
sorry i said it came to 165 was wrong came to 172.80 inc vat did get some other bits at same time
I do know the guy on the counter and he did them trade for me.
LeeT5 (Monday 14th May 2012)
Theres a Volvo independent on Sharrowvale Rd reasonably priced but i cant think of there name!
R pads and disks from Volvo are just repackaged Brembo kit, Volvo buy them from Brembo and repackage and etch VOLVO on, i bought the Brembo disks and pads off flee-bay and saved money, all because it has not got Volvo etched on it!
2003 Flash Green S60R
2008 Cosmic / Java C30T5
Brembo's fitted, the car stops again!
S60 D5, 2002
BMW 545i touring
http://www.ebay.co.uk/itm/VOLVO-S60R...ht_3292wt_1163
I had these fitted and was very impressed. I also had the brake fluid changed at the same time. I do get brake squeal when they get a bit hot but they certainly work well. If you do the rears make sure you have a set of handbrake shoes and the little fitting springs ready to fit as when the rear brake assembly was taken apart on mine the shoes just fell to pieces. Thats a common thing with them.
LeeT5 (Sunday 1st July 2012)
