Right, I know MartinPeachey has done a thread but this is for a door pod and guage. I used an IPD 'R' guage seen here:
http://www.ipdusa.com/products/6153/...ed-boost-gauge
Also i used a Carbon fibre door pod from Carbonfiberwerks....
http://carbonfiberwerks.stimuluscreations.com/v70.htm
You can have them prime the pod if you want to spray a different colour. I primed mine myself using Halfords surface cleaner, 2 coats of primer and 3 coats of top coat Matte black.
OK, on with the mod.
You'll need at least 3m of silicone vac hose as the polyurethane tubing they provide only gets you into the wing under the bonnet.
First of all open the bonnet and remove the Air box or in my case AMS system:
Next, remove the drivers door card following this easy to follow video:
[ame]http://www.youtube.com/watch?v=v_UpoWWpP2U[/ame]
Your door will look like this:
Next, unbolt bonnet catch using a 10mm socket. Pull back carpet, remove footwell light lower shroud and gain access to rubber cable harness trunking on drivers kick panel:
Undo door check strap - shown in this picture:
This will gain you vital access later in the mod.
Undo the two 10mm nuts and squeeze the black pegs at the top of the harness plug. this will come apart.
Pull out the white plugged harness:
using a 4mm drill bit and 2.5mm drill bit, drill into the empty sockets like so....
Undo the other harness that goes through the side of the car and drill out the opposite plug. This will enable you to feed the vac hose and 5amp wire for the light on the guage.
make sure you only push the vac hose as far as the middle harness as you'll need to make a hole for it to protrude through. The 5amp wire will continue into the car.
(To be continued)
