Results 1 to 17 of 17
Thread: Info 13g turbo
    MWT5's Avatar
    Mar 2006
    chester
    27
    Info 13g turbo
    Does anyone have any info on 13g turbo like maximum power it will deliver whats the highest boost pressure it can run what rpm does the turbo start working.
    What is the difference between t5 engine and the lpt engine is it just the turbo?.
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    the t5 is a 2.3 with a high pressure turbo and the 2.5t is a 2.4 with a low pressure turbo
    mitchyboy01's Avatar
    Jun 2011
    Deal, Kent.
    161
    Max airflow is 360cfm. Approx 235bhp although it will be out of it's efficiency range at this power. Max airflow is achieved around 15psi. After this it's just blowing hot air. PS if you want power potential cheap, ditch the lpt and get a T5.
    Grey 855R Manual. Totally standard.
    New Identity
    Dangerous Dave's Avatar
    Dec 2006
    West Midlands
    2,491
    As Frankie says, the 13G was fitted to the 2435cc engine. Maximum boost set by the ecu is about 6psi. The turbo will run out of flow at the higher rpms/pressures so about 13 or 14psi is about the limit. Also the wastegate actuator on the 13G is weaker. On my 13G the max I could get out of it was 9psi (could have been just age). I fitted an actuator from a 16T and it increased.
  5. #5
    MWT5's Avatar
    Mar 2006
    chester
    27
    Thanks guys the reason I asked is the 13g would spool up quick than the 15g .
    I'm just exploring options the t5 engine I have will be racing on short off road oval track where turbo lag is going to be a problem,now I maybe able to sort things by altering gearing and wheel size.
    What worries me is all the talk of rod bending with low down torque ,I can not accelerate after 3500 rpm I would be lapped within two laps lol.
  6. #6
    New Identity
    Dec 2006
    West Midlands
    2,491
    The 13G is good for town driving as its quick spool up is an advantage. Like you say you have to be careful with low rpm boost
  7. #7
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    with the right engine mods to go with it even a 19t won't be laggy, but you will need new rods lol
  8. #8
    Jun 2011
    Deal, Kent.
    161
    Quote Originally Posted by MWT5 View Post
    Leave the 15g on. It spools from nothing, makes great power and makes a perfect very drivable turbo for the T5. Limit boost to 15psi then the rods will be fine.
  9. The Following User Says Thank You to mitchyboy01 For This Useful Post:
    Jamest5r (Monday 23rd April 2012)
  10. #9
    MWT5's Avatar
    Mar 2006
    chester
    27
    Quote Originally Posted by bomb192uk View Post
    That's what Im thinking if the 13g has a maximum of say 15psi surely the engine should be safe whatever the rpm used and the smaller turbo wouldn't produce big torque so less risk of bending something.
    Or Maybe save some pennies for forged rods LOL.
  11. #10
    MWT5's Avatar
    Mar 2006
    chester
    27
    Quote Originally Posted by p fandango View Post
    Hi Duane what would be the best mods to make the turbo less laggy,what I've got planned is 3" dp into 2 1/2" straight through no cat and race silencer,mbc ,rip with large cooler pipes,k&n style cone filter,bailey dv,do have white injectors but not planning on fitting unless I get a 16t (which was the original plan or a Garret) also removing part of the pcv and using catch tank really don't want oil vapour going back through the induction.
  12. #11
    p fandango's Avatar
    Aug 2004
    4,216
    the obvious one to go with that lot is the 960 throttle body
  13. The Following User Says Thank You to p fandango For This Useful Post:
  14. #12
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    I'd stick with the 2.5" dp as going bigger can increase lag (the benefits are higher up the revs).
    Bigger throttle body will help.
  15. The Following 2 Users Say Thank You to LiamT4 For This Useful Post:
    Jamest5r (Monday 23rd April 2012),MWT5 (Monday 23rd April 2012)
  16. #13
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    As above....3" T/B stick with the standard D/P and a 15g...happy days
  17. The Following User Says Thank You to Jamest5r For This Useful Post:
  18. #14
    MWT5's Avatar
    Mar 2006
    chester
    27
    Ooooh there like hens teeth m8 how much bigger is it compared to stock tb
  19. #15
    MWT5's Avatar
    Mar 2006
    chester
    27
    Liam , James I've got to make the whole exhaust as it's not going in a Volvo so I think I will stick with the standard size dp then could always change it if need be.
  20. #16
    New Identity
    Dec 2006
    West Midlands
    2,491
    Oooh, whats it going to be in then?
  21. #17
    MWT5's Avatar
    Mar 2006
    chester
    27
    A front and rear spaceframed vx corsa shell for autograss racing.
