Originally Posted by
cookie
few basics
1 - passenger seat, was there a little 'fly lead' on seat belt clip on old seat, and is it there on new seat (if not seat belt clip will need to be swapped as that is trigger for passenger air bag)
2 - is it same software car to car - i.e. 4.3/4.4/Me7 as IIRC there can be problems swapping between 4.4/4.3 and Me7 not sure about 4.3 to 4.4 or other way round
other than that get codes read, could be something silly not plugged in properly, some generic code readers will reset SRS light, even though they cannot read codes, as when you press the reset, it just tell ECU to clear everything, but obviously only any use if you find wrong connector or the like, so find physical fault, and just need to turn light off
