Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Member
    Aug 2004
    73
    Really freaking irritating whiring noise!
    Didn't notice til I was at MacDonalds drive thru with my window down but winnie is making this god awful whiring noise from the engine at tickover and whilst in motion.
    Steve suggested it may be the alternator - any ideas?
    I just had a blooming shed load of work done to the ungrateful mare and she wants more!!!!!
    x
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Hi Yah.,..
    Umm, depends on what kinda noise it is, it might just be belt noise, they do tend to make a whining noise when they get dry, if that is it then there is a cheap solution, although you can buy proper "belt" lube... I use talc, yep, your choice as to the aroma you want, but just sprinkle a little on them belts, alternator, power steering, if it's belt noise then this will cure it instantly, and smell nice too.....
    Other than that, it could be a bearing somewhere or maybe the alternator brushes, depends if it gets worse the higher the revs...
    Suspended
    855t5r's Avatar
    Nov 2004
    0
    Maybe it was the car trying to tell you that it wanted a Big Mac in a Dolphinesque kind of way
    Ignore me !!!!!!!!
    Member
    Aug 2004
    73
    Cheers Wrighty! It doesn't get any worse the higher the revs so sounds like a belt to me........... Just need a man to fix it now then lol! Nice idea with the talc, I'm thinking johnsons baby powder...or it that too much info!! LOL
    And 855t5r I'm not sure feeding big macs into my petrol tank will do her any good LOL
    x
  5. #5
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Hi yah....
    Talc does it for me..... as for too much info, no, tell me more
    Johnsons, talc, Umm, that makes me mind wander.... stop it..
    Try it, it always works for my belt problems....
    Can't wait for 23rd... the pod... the burn-outs..... have some special tyres put aside just for the job....
  6. #6
    Member
    Aug 2004
    73
    LOL!!!!
    You off to the Pod this month then? Fingers crossed for the weather if you are!!! Make sure you let us know how you get on. Have you made any changes since your last run?
    x
  7. #7
    I have been unfaithful to
    Volvo twice since joining this
    forum but it's only for more
    than 5 pots nuf said
    lance's Avatar
    Aug 2004
    Notts
    946
    Sorry to hear winnies being noisy at tickover, Im off to pengellys on friday as Ive just noticed that my mot runs out on friday too and I want a brake fluid change doing , I will ask there opinion for you!
    2004 V50 T5 SE
  8. #8
    Member
    Aug 2004
    73
    Cheers Lance - that would be great if you would.
    x
  9. #9
    Suspended
    855t5r's Avatar
    Nov 2004
    0
    I still recon its the BigMac problem!!!
  10. #10
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Try turning your heathers off, it may be a noisy aircon pump, mine does it too
    <a href="<a href=http://s65.photobucket.com/albums/h225/RobertBingley/Misc/?action=view&current=Animation1.gif target=_blank>http://s65.photobucket.com/albums/h2...Animation1.gif</a>" target="_blank"><img src="<a href=http://i65.photobucket.com/albums/h225/RobertBingley/Misc/Animation1.gif target=_blank>http://i65.photobucket.com/albums/h2...Animation1.gif</a>" border="0" alt="Photobucket"></a>
  11. #11
    Member
    Aug 2004
    73
    LOL 855!!!
    10/10 Big J! Problem solved when heater is turned off!
    x
  12. #12
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Wink
    HI again...
    Pod, This month, Oh yes, can't stop going, have to get the ol gal running sweet, chasing the 14's.... as for mods, none since the last time, I do have to get my boost problem fixed, have got me some new wheels now, so my old T5 ones will be donor burn out wheels.... I am trying for the best "jo public" burn-out....
    DId manage to get the speedo reading 100mph on one burn-out, now that was smoking!!!!
    Weather, well it it's cold, then great, have to take things out, then we will see if we can get into the 14's.... lets hope....
    I need to see what cheap mods I can do for her before the event, thought about a trip to VT to see what they can do....
    See's yah....
  13. #13
    Suspended
    855t5r's Avatar
    Nov 2004
    0
    Quote Originally Posted by Mrsmopp
    LOL 855!!!
    x
    True!!
    The aircon compressor in mine sounds like Darth Vader with a bad case of Asthma when driving slowly with the window down!
  14. #14
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by wright_t5
    HI again...
    See's yah....
    Just mind you dont blow your diff with the burn out !
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
  15. #15
    wright_t5's Avatar
    Sep 2004
    Cambridge
    2
    Hi,
    Umm, I know, that's why I like to get both wheels spinning... once you get em spinning, they generally keep going..... plenty of water.... helps..
  16. #16
    Junior Member
    adamt5r's Avatar
    Jan 2005
    Ramsgate Kent
    0
    hi mrsmopp,
    i think it could be your alt belt pulleys, mine did so i changed the pulleys as there was wear in the bearings and bingo no more noise!!! but as for the talc, well !!! always worth a try ;-)
  17. #17
    Dec 2004
    54
    She's a lady and she's just winging alot they all do that !! What's 'appenin at the pod? can i bring the golden wonder ? it's too watin cold to run the jedi ! The golden wonder (GW) got heated seats and allsrts !
    hamish.
  18. #18
    Member
    Aug 2004
    73
    Quote Originally Posted by hamish
    hamish.
    Someone called me a lady without having to be prompted!!! LOL
    x
  19. #19
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Sorry to dissapoint Moppy but i think Hamish was drunk, reading some of his other posts.......
  20. #20
    Member
    Aug 2004
    73
    Thought it was too good to be true LOL! Althought the only time Hamish posts is when he has had a few so I should have known!!!!! (You could have let me bask in my ladylike glory for a little longer tho J )
    x
