Page 2 of 3 FirstFirst 123 LastLast
Results 21 to 40 of 56
  1. #21
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Quote Originally Posted by martinrpeachey View Post
    I've had my center console out a few times so if you need any advice or info, feel free to ask. I could have got you the same type of pipe as I used, its nice and stiff, makes it easier to thread through. The pipe that comes with the gauge may be too short too, you will need nearly 3M to get where you're thinking of putting it. Good luck with that mate, keep us posted
    Mate that looks nasty!
  2. #22
    d2k's Avatar
    Feb 2012
    norfolk
    160
    Thumbs up
    Quote Originally Posted by d2k View Post
    thankyou sir.......
    this thread has the exact info i need, ive been planning my boost gauge install for too long mostly b/c i dont really know what im doing, this takes alot of the guesswork out.
    here's what i plan..
    using the same method you did just different mounting...
    thanks again, think i'll try it the wk end (my mechanic quoted me £80 to install so might save a few quid)
    ok so...... finally after following this threads route, i fitted my gauge today.
    route slightly differed over the engine but went in the same way.... took about 2hrs to thread the piping through the grommet into the fusebox but that was the only hinderer.
    here's a few pics.. not too happy with the black filler i used on the vent, so ill carbon wrap that hole i think, or get something black to go over it..??
    just wiring left now.... all cables have been positioned behind the radio, just need to find out which wires on the radio cluster i need..???
    but SUPER happy i finally committed myself to it, the job was seriously daunting for some reason...lol
    Thanks Martin......
    Volvo S60 T5 SE 2002
  3. The Following User Says Thank You to d2k For This Useful Post:
    M-R-P (Thursday 6th September 2012)
  4. #23
    Still more fettling needed,
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Whereabouts on the inlet manifold do you connect the pipe? Can you not tee into the pipe that goes from the turbo to the TCS?
  5. #24
    228k and still not broke it!
    Jul 2011
    Poole, Dorset
    6,548
    No mate, you need the one that goes from the inlet manifold to the recirc valve.
    Looks like a tidy job there Mitch. The cigerette lighter is a good one to splice into for the power supply. Save the risk of annoying the radio.
    310.2bhp / 333ft/lb
    SOLD
    Got an old discovery now.
  6. The Following User Says Thank You to M-R-P For This Useful Post:
    d2k (Thursday 6th September 2012)
  7. #25
    Lawnmower Boy
    Now known as WAPAHO!!!
    JUDGENINJA's Avatar
    Nov 2004
    Guildford, Surrey
    1,058
    That's a very odd route for the piping... Is there no rubber grommet behind the glovebox or behind the fuse box?
    It might be an 850/P1 thing..
    Current Garage:
    *Data Sept 2013
  8. #26
    Jul 2011
    Poole, Dorset
    6,548
    Quote Originally Posted by JUDGENINJA View Post
    There's a few but they're an absolute pig to get at from inside.
    310.2bhp / 333ft/lb
    SOLD
  9. #27
    d2k's Avatar
    Feb 2012
    norfolk
    160
    morning all........
    need some urgent help with my wiring..... my car is currently in bits, lol
    im gonna tap into the lighter as suggested but there's no chassis bolts anywhere in the center console for a ground..
    the 2 cables coming off the lighter (purple / black), im guessing purple is live & black is ground / negative...???
    can i not just run the gauge pos & neg straight into both of the lighter connections...???
    thanks...
  10. #28
    Jul 2011
    Poole, Dorset
    6,548
    yes mate, you can
    310.2bhp / 333ft/lb
    SOLD
  11. The Following User Says Thank You to M-R-P For This Useful Post:
    d2k (Saturday 8th September 2012)
  12. #29
    d2k's Avatar
    Feb 2012
    norfolk
    160
    sweeeeeeet.......
    time to cut...
  13. #30
    Jul 2011
    Poole, Dorset
    6,548
    Go, Go, Buffalo!
    310.2bhp / 333ft/lb
    SOLD
  14. #31
    d2k's Avatar
    Feb 2012
    norfolk
    160
    Thumbs up
    IT WORKS!!!!!
    now i just need a crash course in what it 'should' be doing..
    when i start the car it reads 20-22psi vacuum..
    when i pull off 2krpm it moves to 15psi vacuum..
    when i boot it, it reaches 12-13psi boost (which is pretty good i thought)
    though it never sits at 0psi..???
    when cruising at 60mph 5th 2.5krpm ... the gauge is reading 10psi in vacuum..???, only when the revs go past 4k does it pass the 0 & move into boost..???
    is this right..???
  15. #32
    will it never end?
    stribo's Avatar
    Jan 2012
    Tadley
    2,620
    Doesn't sound right mate, boost should start before 2000 rpm, though you will get vacuum at idle.I'd check the pipework doesn't have any leaks.
  16. The Following User Says Thank You to stribo For This Useful Post:
  17. #33
    d2k's Avatar
    Feb 2012
    norfolk
    160
    thanks stribo.......
    looking closer at the gauge im only actually getting 11psi i think, im gonna wait till it gets dark & throw up a vid....
  18. #34
    VPCUK Car of the Year 2013
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Sounds about right to me, vacuum on idle is spot on and yes it will be in vacuum when crusing I'm guessing yours is not mapped as the boost comes in late but all looks good.
  19. The Following User Says Thank You to Jamest5r For This Useful Post:
  20. #35
    This status has no user
    cherry1809's Avatar
    Jul 2008
    Miles from anyone
    1,816
    No, it should come out of vacuum and at least stay at 0 until boost reaches a positive pressure. If your just pootling around off boost it shouldn't hardly move off 0. If it does, I'd say your gauge is poo.
    Current Chariots...
    Micra K11 'project sh*tbox'
    V70 D5 daily
    1991 Transit Recovery
  21. The Following User Says Thank You to cherry1809 For This Useful Post:
  22. #36
    d2k's Avatar
    Feb 2012
    norfolk
    160
    Quote Originally Posted by cherry1809 View Post
    lol.... well we know the gauge is poo , so i should be seeing 0psi while cruising with no boost...??
    from what ive read, a decent vacuum shows a healthy engine..??
  23. #37
    Jim
    Jamest5r's Avatar
    Feb 2009
    Kangaroo land
    7,069
    Mine only goes to "0" if i squeeze the load pedal a bit to create positive vacuum, normal driving it stays negative and thats with a AEM digital gauge and it definatly not poo lol
  24. The Following User Says Thank You to Jamest5r For This Useful Post:
  25. #38
    Jul 2011
    Poole, Dorset
    6,548
    right, hold on... I'lk go get a vid of mine which has been calibrated...
    310.2bhp / 333ft/lb
    SOLD
  26. The Following User Says Thank You to M-R-P For This Useful Post:
  27. #39
    Jul 2011
    Poole, Dorset
    6,548
    The rettling noise is the camera bouncing off the A-piller - aoplogies
    310.2bhp / 333ft/lb
    SOLD
  28. The Following User Says Thank You to M-R-P For This Useful Post:
  29. #40
    d2k's Avatar
    Feb 2012
    norfolk
    160
    well..... my gauge is working EXACTLY how it should be going by this video (cheers martin)....
    as my vid will now show, its pretty similar to martins.... gauge stays well in the vacuum most of the time.
    View My Video
    please excuse my talking, please mute it if im annoying..lol ... my daughter had to change gear while i held the phone so its a little shakey..
