Since buying my S60R last October I noticed a clunk when moving away/engaging reverse or 1st gear/changing between 1st and 2nd, and lesserly between 2nd and 3rd.
I read about axle ping and changed the bolts for the XC90 ones, this didn't seem to change anything, and also changed the gearbox mounting bush with similar results.
I recently bought an engine top mount/"upper anchorage". I looked at the loose fitting of the rubber bush inside the aluminium housing and gave it a 1% chance of making any difference. However once I swapped it (why did they put all those poxy plastic covers on the top?!!) I am delighted to say it has cured it 90%! Reeeeesult! The car changes gear much more smoothly now, well chuffed.
However I still want it to change gear without clunk at all and am thinking that wishbone bushes are next on the list.
So, the question is, how much harsher are polybush, and are they worth the work involved?
Or should I just buy new Volvo wishbones?
What are the rough costs involved in both options?
Thanks in advance as always.
