Hi guys....
There are a fair few threads on this valve but none that I can see which explain what products people have used to get the best results.....Mine looks really clogged.
First off are there any internal parts which will be against the use of brake cleaner or a pipe cleaner?
I have been recommended to clean it in situ as a few members have damaged the rubber seal trying to remove it and then had to buy a whole new intake hose!
So what products have you guys used for best results?
If I'm doing it with the intake pipe off the car I need to make sure that whatever I use pushes all the gunk into the intake pipe where I can easily pass brake cleaner/rags through.
The engine is low mileage(90k) so I hope this is the main offending article and I won't need to replace the rest of the PCV just yet.
Cheers
Alex
