Hi guys,
Got an issue with the 850 I just picked up, not worried as the work to fix it is going to be paid for by the previous owner as soon as I diagnose it.
Ok so I left northampton with the car on max line for coolant......I checked and checked again, no mayo in the oil, no oil in the coolant, no smoke on startup or when running/overrun. No overheating either.
Series of events.....
Took ages to get warm and up to halfway.
When it eventually did it would drop down to a third temp whilst on the motorway.
However on stopping or trafiic/lights, the temp would rise to half way again....Once fan kicks in it begins to drop again on the open road.
Coming up to services I noticed upon hard acceleration the low coolant light was flashing due to it reading below minimum when accelerating hard/nose lifting.
So I got 10 miles from home and popped the bonnet whilst I grabbed a kfc, just to check everything again.
This is when I noticed the coolant level was at minimum....So I slowly opened the filler cap to release any air if it had been getting blockages. Low and behold a massive amount of air released and the coolant level came back up to near the max line.
I noticed when home and engine cooling down that on sqyeezing the rad pipes, you could hear air stuck in there.
So after a long run I now have to release the filler cap and any air blocks to get the coolant to sit right again. If I just keep driving it the coolant level continues to drop???
I had to top the system up with 300ml to bring it to the max line.
There are no leaks anywhere at all, no split hoses, no overheating....Just a temp gauge that fluctuates between half and a third, and a lowering level in the filler tank.
My thoughts -
Sticking thermostat?
Would this cause the dropping of running temp as it is getting partially stuck open at times, and could this prolonged action be causing air locks? Finding their way to the filler tank, therefore pushing the coolant around the system and making it look like it has lost cooant in the filler tank?
Or
Wrong thermostat? Opening and closing at temps different to that of volvo specs....so causing fluctuating temps.
Or
Headgasket? But surely I would be seeing high temps/mayo/oil in coolant, boiling coolant....
Any ideas?!? I am mechanically minded and can do most things but if its more serious I will need a garage to do the work.
