my exhaust gases rally honk of unburnt fuel!!! any ideas ? is the mixture only set by the ECU or has some monkey had a fiddle ? when i bought the car the chav said that you can adjust the mixture useing the brass 'screw' on the passenger side of the fuel rail! made me think hes had a tinker with it , for whatever reason , and buggered things up!!! my car has the ecu port in the centre consol - is it a main steeler job to get the fault codes read ? is there anything obvious/common faults i can check for ? can put it onto a gas analyser to get a co2 reading if that helps! HELP mikey
