Page 1 of 2 12 LastLast
Results 1 to 20 of 31
    Feb 2012
    42
    Power Steering Pump?
    Hi all,
    Iv been informed that the whining i can hear is indeed a noisy power steering pump.
    Should i worry too much should i look into getting this changed as soon as i can, if i do, where is best to get one from as it seems to be a bit of a minefield of different types of pumps!!
    thanks, andy
    Just cant keep away from the
    Ovlovs lol
    daza-b's Avatar
    Nov 2011
    Somewhere in England
    1,191
    what sort of car is it, also whats the part numbers etc? i have pump hanging about
    Back with a 1997 S70 T5 SE
    Feb 2012
    42
    Its a c70 T5 1999 v reg
    Ovlovs lol
    daza-b's Avatar
    Nov 2011
    1,191
    not sure if they are same..should be, can you take a picture of yours and post it for me please, need to tally up the part numbers etc
  5. #5
    Skint and kanckered!
    I want a T5's Avatar
    Dec 2011
    Folkestone
    3
    I had heard that filling it with Slick50 steering fluid helps......
    It may just be snake oil though!
  6. #6
    Feb 2012
    42
    tbh, i can live with it so long as its not an urgency to change it
  7. #7
    This user has a status
    s_cowen's Avatar
    Nov 2011
    Northumberland
    38
    Hi when i bought my s60r a few days later it developed a wining noise from the power steering & I panicked thinking it could be the rack or pump but luckily I found this very useful thread which turned out to be the problem,
    http://www.volvoforums.org.uk/showthread.php?t=110646
    Less than an hour & it was sorted & still fine now.
    My03 S60R, 340bhp Rica remap, Tinted windows, Stainless 2.5" cat back exhaust system, FMIC.
  8. The Following 2 Users Say Thank You to s_cowen For This Useful Post:
    andybrown (Tuesday 14th February 2012),kyboy (Friday 20th July 2012)
  9. #8
    Feb 2012
    42
    Thanks, that looks like a good first point of call, so do i just literally take the res cap off, and look for a piece of plastic, and stick it back on?
    I notice someone drained the res with a turkey baster, is it a case of just drain it into a clean tub, then....pour it back it?
    Please excuse me if i sound simple!
    Andy
  10. #9
    Feb 2012
    42
    Just checked and indeed i am only seeing the brass pipe, il have a good go on saturday then!
  11. #10
    s_cowen's Avatar
    Nov 2011
    Northumberland
    38
    If all you see is the brass pipe I am pretty sure this will be your problem,
    It was very fiddly & I couldn't work out how to do it at first!
    I sucked all the fluid out first with a large syringe & pipe & then removed the reservoir, the brass pipe will need to be pushed back out flush with the inside of the reservoir to enable the L shaped pipe to be put back into place then once in place tap the brass pipe fully back in as this is what secures the L shape pipe in place, Then just refit the the pipes back to the reservoir, refill with fluid & presto no more strange noises feelings through the power steering.
    Hope this helps!
  12. The Following User Says Thank You to s_cowen For This Useful Post:
  13. #11
    Feb 2012
    42
    that helps a lot, does the fluid go all over the place on taking the res reservoir off? never done anything like this before!!
  14. #12
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    You suck all the fluid out first, but, there will be some fluid lose
  15. The Following User Says Thank You to Volvostorm For This Useful Post:
  16. #13
    Feb 2012
    42
    ok, if it needs topping up, please dont tell me theres multiple fluid types!! ;-)
  17. #14
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Should tell you in the handbook for the car, its normally ATF fluid
  18. #15
    s_cowen's Avatar
    Nov 2011
    Northumberland
    38
    Makes you wonder how many people would get there pumps or racks changed when its only a simple fix!
  19. #16
    Feb 2012
    42
    Quote Originally Posted by s_cowen View Post
    yep, i was pricing up pumps yesterday before i saw this!
  20. #17
    Cubes's Avatar
    Jul 2008
    Middlesbrough
    1
    I had the same problem with my 02 C70. The reservoir caps are pressure valved and are renowned for failing. My first port of call would be a new cap.
    Meet Abby, an elegant lady... Still, very willing to go topless in public. All I gotta do is push the right buttons...
  21. #18
    Feb 2012
    42
    Any idea where you get the caps from mate?
  22. #19
    Cubes's Avatar
    Jul 2008
    Middlesbrough
    1
    I got a second hand one from my local Volvo specialist but, to be honest, I don't think it'll put you that much out of pocket to buy one from the dealer. It'll still be your cheapest option (and remedy too hopefully!)
  23. #20
    Cubes's Avatar
    Jul 2008
    Middlesbrough
    1
    Would these guys be able to help? Not sure what they're like. I was told about them when my (now ex) girlfriend lived there:
    CLICK HERE - volvospecialistderby.co.uk/
