I have a r reg c70 2.4t.when I got the car it was low on oil but didn't put me off as been serviced every 10.000 miles and everything was find.now I checked it the other day and my oil level was low practically empty I've only done 3.000 miles and the dipstick had mayonnaise on it it's not over heating and no exhaust fumes out header tank so am hoping not the cylinder head.temp stays normal on gadge.but I checked the water pipes to engine from radiator top hose gets hot and pressures right up so pipe is hard but bottom hose is freezing cold and no pressure I'm guessing water pump has seized and engine oil has been cooling engine making level drop fast. I'm just wanting a second opinion
