£550, could be done cheaper, but £550 is not a bad price
Hiiiiii guys, I was getting lonely!
Once the Beta-test kit has been finished and fitted/run to confirm the brake lines and clearance etc on the car, what I'll do is confirm the final fixed price and take deposits for kits from the first batch. I'd want the rough timescale to be: Deposits at about the middle of the month, delivery between 1 to 2 months after that (balance due when we're ready to ship).
Cool - for the S70R the first kit will be another Beta Test, reason being that the kit is being done "for" a "96 850 T5 GLT and other compatible cars". So while I've been told it will go straight from the 850 to the S70....I will need to confirm that for myself. It should be pretty easy to do though!
Cool, noted.
Can get disc cheaper than £180 and calipers
you wont get the calipers for less than £180
http://www.ebay.co.uk/itm/Renault-Cl...item51a22c0dd1
http://www.ebay.co.uk/itm/1809462067...84.m1423.l2649
http://www.ebay.co.uk/itm/1608566023...84.m1423.l2649
Extremely interested in the large kit for the 850, please mark me down!
i could be interested in some for my s70r depending on when the money is needed, with xmas rapidly approaching,
Thanks guys, noted!
Ok, I've been doing some profile testing (thanks Ant) and the results are:
A - 330+323x32mm T30x caliper kit in 17" Satelite = 11mm wheel spacer (give or take a couple of mm) needed due to the thick caliper (the diameter is ok).
B - 330+323x32mm T30x caliper kit in 17" Volan = 9mm wheel spacer (give or take a couple of mm) needed due to the thick caliper (the diameter is ok).
Therefore (as the T20 caliper is a touch over 11mm thinner on each side):
D - 310(maybe 323)x32mm T20 caliper kit in 17" Satelite = "0mm" wheel spacer (give or take a couple of mm) needed
E - 310(maybe 323)x32mm T20 caliper kit in 17" Volan = no wheel spacer needed
...and...
G - 302x26mm (C70 disc) T20 caliper kit in 17" Satelite = no wheel spacer needed
H - 302x26mm (C70 disc) T20 caliper kit in 17" Volan = no wheel spacer needed
Not what I was hoping for in the case of the biggest kit but the T30x is a big and very stiff caliper.
So, what do people think? In simple terms it's 330mm/big caliper which needs 10mm-ish spacers vs 300-320mm/smaller caliper and no spacers.
big brakes, big calipers, i think they will fit my wheels
These are 320 m/m discs with brembo calipers behind Volans with a 5 m/m wheel spacer.
Ali-Bongo (Sunday 7th October 2012)
No spacers :-)
Old Cars: Mazda6, Laguna 2.2, S40 T4, Passat 1.8t, Celica GT4, Legacy GTB, Golf VR6, S70 2.5t, C70 T5
Current Car:850t5
I'm hoping the Titan has more room to be honest! Failing that 320x28 with the smaller caliper (no spacers) or with the larger caliper (5mm/volan or 7mm/Satelite) might be the best bet.
I'm posting some pre-cut templates to a very helpful Titan owner, fingers crossed!
Just seen the above post!!!
Looking forward to hearing the results, fingers crossed!
what was the result for the 17" comets? Personally I'd have the 320mm calipers & no spaces.
Volvo ABS ECU Repair
I haven't had access to Comets as yet - if you wanted to PM me your address I can post out some profiles to you too?
Address sent.
Thanks Dave!
Does the 850 have a removable lower balljoint, or is it part of the lower arm/wishbone? Sorry if I already asked!
There are currently 10 users browsing this thread. (0 members and 10 guests)
