Hi, just wondering where in the uk i can get a rebuild kit for my 18t, as she is starting to smoke.
Also is there anyone on here that rebuilds turbo's? if not i may give it ago myself.
Any help Much apreciated.
i dont know if its for an 18 but ive seen rebuild kits on the bay of e!!!
full respray..plenty of body mods..comets..ray cat back noise pipe..decat and wrapped downpipe..me7 exhaust manifold..3" throttle body with ported inlet manifold..blue injectors..adjustable fuel reg..reverse intercooler pipework..19t..open cone air filter..255 fuel pump..m-r-p short shift..boost gauge..unknown remap..adjustable suspension..lightweight crank pulley..n/a cams..stripped out interior..and a heavy right foot
merc85 (Tuesday 27th December 2011)
turborebuild.co.uk do a brand new core for £230
Turborebuild.co.uk also do diy rebuild kits, I've had one from them before and it was fine. Only problem is that the turbo really should be balanced after a rebuild, but most places won't balance one unless they do the rebuild.
18T will need a 'super back' washer. Dont buy a flat back kit.
Heres a super back rebuild kit. Or..search ebay for a td04 rebuild kit and remember it has to be a super back.
http://www.ebay.co.uk/itm/Mitsubishi...item336edabac6
ive rebuilt many turbos chap. Happy to do it for you.
only this one in the uk. Doesn't say if its super or flat back.
http://www.ebay.co.uk/itm/Td04-Repai...item5ae3bfbd40
personally i've take the turbo to a specialist to get refurb'd, i've seen turbo that have had ebay rebuild kit that are still knackered because its not as simple as replacing the seals/bearings. If the bearing are worn then the excess shaft play would cause the fins to touch the inside of the casing, plus it would need rebalancing as soon as you've touched/moved the impellers
Ive rebuilt my 15g and it was fine
I said a 10 second car not a 10 minute car
me to and not just volvo turbos......as long as the turbo is just smoking and shaft wear is ok and the kits come with a bearing and all seals so no probs there..just make sure your work place is clean..
we rebuild all our work vans and we dont balance them as have no means to do it we only buy a new/recon core unit if vanes have broken or touched the side.so far only ones that come back are due to driver abuse from not checking the oil weekly
i'm sure they only balance them for fun anyway, not as if there spinning at a high rpm or anything
i know many that have rebuilt turbo's & work fine, i also know some that haven't. If was me i wouldn't risk the time & effort of taking it off to do a half job, get it done properly & know its right
AndysR (Friday 30th December 2011),p fandango (Thursday 29th December 2011)
bigrotch (Thursday 29th December 2011)
