How can you tell the difference from the gas and oil shock.Ive fitted a pair of shocks to my car and one side sits higher than the other by an inch
I said a 10 second car not a 10 minute car
Yes gas shock rebound, oil don't. I.e oil shocks slow the movement of the spring and gas shock try and push against the spring to straighten it. Most gas shock are still filled with oil.
Gas being the better shocks
Im trying to work out why my car sits higher on one side by an inch?
did you install the springs correctly? and tighten down the mounts
