I wonder if anyone can help? My r is running a forge mbc, forged internals and I've adjusted the actuator to get rid of any free play, it's running a standard ecu and I've got the mbc set to 15psi, I know cold weather will help spool up but it seems to hit the fuel cut now in 5th in no time at all, if I give it a boot full on the motorway overtaking the boost gauge shoots up straight away where as previously the car has took longer to spool in theory making the gears feel longer,it's certainly still a quick car but different in it's power delivery? it spools so quick now the car seems slower ?it's not clutch slip or anything daft like that,it can't have a leak as it holds boost an I wouldn't expect it to boost so well with a leak? Should I just back the mbc off a couple of clicks until I get the car remapped?
