Just wondered if the ones I had bought were the same as the ones you thought were too blue
If so we need to try some other ones.
Alastair
Most Volvo dipped beam run H7 bulbs. The 35W balasts are more than enough to give you the intensity. You can spend extra on 50W balasts but there is little point IMHO. You need to choose the lght colour. 8000K are a bit blue for my liking. I have 6000K ones. I also run HID on main beam. Takes a little while to warm up - flashing still works fine - & it is only the first time you put them on that it takes 10 seconds for them to come to full strength.
I recommmend using H7R bulbs on reflectors to avoid glare.
Best to take out your dipped beam bulbs - find out the size & choose a kit accordingly.
Sides can be done with LEDs - again it is just a case of matching the bulb size to the replacement.
Volvo ABS ECU Repair
Alastair
These are like the ones i bought Al http://www.ebay.co.uk/itm/2006052979...#ht_5073wt_952
Martyn
FAO Al and Martyn, i had leds in my front side bulbs but i didn't really like the non oem look. They also were not as good at filling the lense with light as an oem bulb. So i outed them and refitted new 5W wedge bulbs. Much better light and look stunning against the Bi-Xenons (I think). the leds i tried were 9 led per bulb. They were incredibly bright but in the wrong reflector they are crap! Work amazing as front sides in a Vivaro with the late shape headlamp cluster. Got them in my AA van and they are blinding...literally!!!
Al115 (Saturday 17th December 2011)
sorry my bad - you are right - I meant Watts not Volts -
Talking of LEDs....gonna convert my rear light clusters to the late shape 54> with the leds in the sides and more crystal looking lenses. get me some colour coded bumpers and no one would ever know!
Already got a pair
Alastair
Sorry al forgot to write back, i dont think my leds are the same. U got the new ones yet?
Martyn
Yep, I've got them, but they look pretty flaky...
Will whip the headlamp out when I have time. Need to learn where all the bolts are on this new car
Alastair
Dont take the light out, i think the bumper needs to come off to do that
Martyn
Al115 (Tuesday 20th December 2011)
How do you best get to the stupid sidelights without?
Monkey hands to the back of the light? Or through the wheelarch?
Alastair
Very difficult i just used my hands from the back of the light, theres a picture in ur manual the passenger side is the easiest.
Martyn
OK I will test on the pax side then thanks
Alastair
volvokid (Tuesday 20th December 2011)
Done yet?????? Hurry up :^)
Martyn
Not today sadly
Wed/Thurs I hope!
Alastair
Could u put the battery across the terminals to see them on? Could save u struggling to fit them and find out there crap
Martyn
