Sitting in M&S car park meditating on the fact that my drivers side wiper has just stopped wiping and can be moved manually...what is solution? Other one works fine. Cheers in advance. Ooops here comes Mrs...must go.
KISS Rs
850R manual, Rica 310, IKEA fitted bathroom, H&C running water, Jetex 2.5", pipe rack, cap stand, Forge BOV, circular wheels with full 360 degree rotation, 302mm discs, IPD front and rear anti-roll bars, numerous shiny features, sub-atomic particle accelerator, VTOL capability ...Volvo With Attitude!!!
Also to be seen in a gold Honda CR-V these days...
"It's really fast, and growls like a tiger!"
the bolt the holds the wiper to the spindle will be loose. just tighten the bolt and it'll be fine. should be a 13mm.
Flatout Phil (Sunday 20th November 2011)
I had the same on an ex cop car I had, if you can't tighten the nut up any more then you need a new wiper arm. As the arm is aluminium and the wiper shaft is steel if anything sticks it's the arm that knackers up, thankfully it's an easy fix.
Previous cars:
arm nut = 8mm. If the splines are fubar'd, replacement motor. lost count of how many I've got spare. If I can help feel free to ask. Pass side EASY to change, drivers side, bit of a pain coz theres not enough clearance to remove the motor. You'll need to shift the rad pack back a bit to gain clearance.
KISS Rs
