Don't take it personal fella, i wasn't intending on upsetting you. I just wish people would read the question before replying thats all. Saves me and others trawling through useless replies. If you can't help, thats fine
Also, if it was pointless me asking then i ask you...What's the point in VPCUK?
I'm sure were all here to help people including myself, but threads would be alot cleaner and would take a hell of a lot less time to read if peoples replies were relevant.
To answer your point about it may be the throttle body...well yes, it may well be the throttle body but that wasn't what i was asking. With no DTC's, 35mpg at 70mph and acceleration totally normal, i doubt very much if its the T'body.
I have a BSR code reader that can read codes as per VADIS language for example - ECM 1234. There are no codes at all stored.
All i was asking was that if any fellow R owners could perform the little test as i first posted and let me know how they got on. If 100% people report No problems with high idle stability with the clutch pedal down or up, then i know i have a problem. however, if some people report the same symptoms as me then i know that there is an issue that needs to be addressed.
I am going to remove the BSR map at the weekend to see if that makes a difference, but i doubt it will.
I know the clutch pedal switch is related to cruise control and therefore throttle control so i'm wondering if i need to be looking at the pedal switch as a faulty component, however, the cruise control works fine.
Any help would be greatly appreciated.
