how do you remove the rear shocks on the t5 estate..I can see there is a bolt on the bottom of the shock and i know there is a top mount but does this undo from inside the car or from underneath..Got a rear mount which makes a noise on the offside which needs changing by the sound of it,and as yet havent looked fully under the car but had a quick look inside the car and couldnt see the mounts inside unless they are under the boot carpet bit..
