Hi all,
Right I've had the crank sensor replaced, vac lines replaced, temp sensor and thermostat all replaced. MAF and plugs cleaned. Running much better but still seems to hold back between gear changes when gunning it. I mean it boost up to 5k rpm change gear foot down, hesitate (more than just lag) then boost fine till next gear change. Any ideas? Actuator? how do I check and adjust this?
Cheers in advance
Neil
