hi had loads of probs with abs of late..... cleaned all abs rings they look good i bought a abs ecu and pump off a member on here which was reconditioned unit etc replaced that still had problem after replaced that... just put upgraded discs pads calipers and diff abs sensors on the front, bleed whole system again... brake pedal feals aloat better but the abs and trac light is on constant... will it need to be reset or do i still have a prob....
