Originally Posted by
merc85
HI there, after a new blanking plate, no dv i'm sure i still have this damm Boost leak. Also running a Forge unos which is excelent.
She can hold and increase Boost very slightly but then loses upto 5psi of Boost although slowly.
Also when i change gear then rpm's increase by 300rpm between Gear changes. She also POP's on the Over run.
I have Cleaned the idle control valve,Throttle body, changed the tps sensor, sprayed carb cleaner around the intake hoses, and she doesn't pick up.
But as soon as i drive along and change gear she rev's between the gear's
I Really do think the 2 or conected. (cracked Turbo exhaust housing)???
