You wont need to modiffy the bulkhead. If using the standard log type manifold you can have the lip machined off and a slightly increased taper at the same time to help with clearance of the water pipe then it should fit. Depending on what Turbine housing you use clearance should be okay. Try getting one with as small a housing (AR and physical size) as possible to keep the spool time down and that way you will have a powerful car with a larger power band.
