Originally Posted by
Porcine_Aviator
I'm confused as to how the guy who looked at your brakes could say that fluid is leaking into the gearbox!
The braking system is closed and runs through the car via hydraulic pressure from the master cylinder and a reservoir that holds the fluid. To my knowledge at no time does it pass through the gearbox, why should it?
There could be a loose union at any of the wheels or joints through out the car, get her up in the air and go through all the pipes looking for breaks, cracks and any sign of fluid on the underside of the car. Take off the wheels and check all the unions to the discs and make sure that they are tight. You could get the system pressure checked, this involves getting the fluid in the system put under pressure as in having them bled through, then while it's under pressure get underneath and follow all the break pipes this could show up where the leak is.
The master cylinder could be leaking and would need replacing, or even the reservoir could have a small hole in it.
Are your brakes spongy, or do they have a lot of travel?
Again I can't see how the garage guy can say the brake fluid is leaking into the gearbox, unless they are after lots of money!
