I have read all of the posts i can find on the forum about alarm issues and I am almost 100% that i will need to replace the alarm siren module.
Could anyone suggest anything else prior to buying the kit?
Without notice after a long very wet return down the A1, the alarm went off after moments of parking and locking the car. It now goes off intermittently when it feels like it. I have tried parking it with the interior sensor disabled - no difference.
I do not have any service messages other than the normal Alarm triggered - check car after turning ignition on,
I have adopted locking the car with the key therefore the alarm not getting set - this results in 'alarm free' nights of sleep.
I have returned to the car a couple of times and found all the doors except the drivers door unlocked. Only since this problem started.
I have locked the car with the key and waited about 30 secs until you get the second 'clunk' which i presume is the deadlocks engaging.
It seems to be at this point that the rest of the doors unluck. However I cannot be totally sure as i have only seen this once.
I found a procedure for a UEM reset in one of the threads and did this today, I also give fuse 8 (rear fuse board) a good wiggle as this is mentioned to be the fuse for the alarm.
Any suggestions would be useful, i intend to use the alarm as normal during the day to see if any of the above actions have remedied this, other than that does anyone think the central locking issue is attributable to the alarm siren module dying?
