Results 1 to 8 of 8
    Junior Member
    Nov 2009
    0
    V70 T5 handling problems
    My 2003 T5 steering seems to be all over the road & very light. I have replaced the wishbones & still feels the same, steering rack seems to be fine but on roundabouts can sometimes give all I can describe as a slight kick. Any advice on the faults & quirks of V70 steering would be greatly appreciated.
    Demented Tonka Toy
    t5_monkey's Avatar
    Jan 2009
    Glasgow
    2,387
    get your alignment checked and droplinks I think ?
    BSR stage 3, BSR Stainless Exhaust, Vibratechnics gearbox Mount, OZ 17" Superturismo Alloys, Bell FMIC, LED Side lights, LED interior Lights, Tinted Windows, Eibach Sports Springs, K&N Air Intake, 3" Sports Cat and Downpipe, Debadged, EST Strut Brace, EST Grille, Black Moose Stickers, Bilstein B8 Dampers, Fully Polybushed, CC3 all round, CF Wingmirrors
    Release the Monkey inside of you >>> Trunk Monkey
    Casual poster 15 years on!
    Murphy's Avatar
    Oct 2004
    Derbyshire
    100
    As above, plus you should check top mounts. If you have been scrubbing your tyres, once properly aligned it could still feel odd. With fresh tyres [not essential] it will be back to where it needs to be though
    My TWITTER username
    If in doubt thrash it and see
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    Agreeed - get tracking checked but while off the ground get all susp joints at front checked for play inc rack mounting brackests and subframes.
    If you have had tracking issues or needed replacement arms as you say presume the bushes or b/j's where knacked - you will prob have worn the tyres unevenly and that will show up as a problem.
    Easy check is put the rears on the front and see if it changes the problem, then you'll know and could just get them all truned round or replaced if nec.
    Good luck - I know it can be frustrating but a methodical approach will most likely find a simple cure.
  5. #5
    Niles's Avatar
    Jan 2006
    On the Verge
    470
    I agree with the others. If I were you I'd go and buy 2 new drop links & 2 new rubber top mounts. 99% chance both those items are very worn or beyond their best. If you go you euro car parts both a pair of drop links and a pair of rubber top mounts shouldn't cost much more than £65 the lot. Totally worth the money.
  6. #6
    Junior Member
    Nov 2009
    0
    Thanks for the advice, have had tracking done and tyres are worn on outer edges so will try swapping front to back. Will try replacing drop links & top mounts as having done 127000 miles I agree they are probably past their best.
    Can the anti roll bar bushes be replace as volvo say they are part of the bar & don't come seperate ???
  7. #7
    what happens
    woz's Avatar
    Mar 2005
    Bristol BS5
    58
    suggest you do the cheap things first.
    ARB bushes can be replaced, but I took a set into the garage and he tried then gave me them back said it cant be done. Dont entirely believe this so planning to have a go myself as its all in the Haynes book - involved but straightforward.
    Based on experience with other carss, its worth doing if you are pulling all those bits in the nether regions apart anyway. But wont make much differnce to handling until they start knocking.
    Keep us posted. My moneys on the tyres!
    W:>)
    Dont forget different models have different thickness ARB's
  8. #8
    Junior Member
    Nov 2009
    0
    If I ever get a day off I will have a look at it & start by swapping tyres round. Hopefully that will solve it, if not it will be a process of elimination. Wish me luck
