im having a problem getting tyre off as the attachment for the lockable nuts wont go on the nut, it used too but now wont, were all the lockable nuts the same with volvo's, as dont know what to do as got flat and cant get it off
sounds harsh mate , do you carry a can of tyre foam? you could use that to inflate the tyre to get you out of trouble till you cure the real problem which am afraid could mean a lot of drilling the old bolts out etc or using stud extractors
volvo340sleeper (Tuesday 2nd August 2011)
theres only one bolt which cant get off, will go buy tyre foam 2row, guess they all different and wont be able to find one the same as bloke down road has got v70 with same alloys
What sort of locking nut is it?? some you will get away with smacking a 19mm socket over the top
T5frankie (Wednesday 3rd August 2011),volvo340sleeper (Tuesday 2nd August 2011)
its a round one
I had the same problem. Took it to the Local volvo dealer and one of the lads managed to get them off using a heavy duty impact gun.
It destroyed the lockers but was way better than having to start doing it the other ways.
how much did it cost
is there anyone local to me who would be able to see if theres fit,
Can you post a pic up of the locking nut? many people on here have been through the same problem but there are so many types, some easy to get off and some not so.
I managed to get it done for nothing but its just because i knew one of the lads in the parts dept. Any garage that uses air tools will usually have an impact driver so you could prob get it done cheap enough.
Just carefull they dont damage your wheels while doing it.
just looked on halford and they do a laser remover anyone used them before
JT (Tuesday 2nd August 2011)
will the 850 fit the s70 then? if so how much
just bray a socket onto them/it i had to do it on a car this morning 18mm socket a good smack with the hammer and bobs ur unlcle
not sure if you mean the wheels or Johnny's locking wheel nuts. But all the wheels fit each other, i swop wheels between my S60 & 850. You do have to watch brake clearance's if your using 16's or smaller. As for the wheel nuts, yes his 850 one's will fit your S70
here is the locker
Not a lot of Volvo dealers will admit this.... however. They all should have a set of master lock nuts.
I took my car to John Darke in Lincoln and the technician brought out a case with every locknut Volvo produced.
They all have them as many owners dont leave them in the car when they go in for servicing.
Give your local dealers a call, they should be able to help.
Arguing is pointless....she may not be right but she's never wrong
Tell her a remap is just having your satnav updated.....
volvo340sleeper (Wednesday 3rd August 2011)
just went and bought a laser remover for them as cant really drive car as the tyre i need to take off is illegal and flat
