My windsceen wash/wipe can only be activated by pressing the stalk which should activate the rear wash/wipe - in doing so the water only goes to the screen and not the back window. I've pulled the washer bottle and only appear to have one pump with a two pin connection located at the top of the bottle which would appear to be for the rear window only. At the bottom of the bottle there is a blank which I assume should be for the windscreen/headlights pump?? My problem is that I don't appear to have a "spare plug" to power the missing pump (are there two pin connection also?) and the only pipe I can find which may feed water to the rear window is a pipe which disappears into the bulkhead which is flexible plastic with about 3 inches of rubber at the end. Could this be the rear window water feed?? I don't want to connect and pump water through in case it is possibly connected to something electrical out of sight.
