Folks need some advice here. Im affraid my technical knowledge is lacking and my ability to undo nuts everymore improving.
Basically I am removing the head off a donor T5 engine to get skimmed and refurbed and placed onto my engine as the valve stem seals are shot.
I have removed the cambelt etc and began to remove the cam sprockets however after removing the last nut on both sides the drill bit I used to keep the cams in place didnt work and both have moved considerably from their original loaction.
My question is what impact will this have? Is it mainly important for the bottom end or am I likely to have ruined the top end too?
If they need to be in the correct place can they be re timed up with relative ease as this if applicable will obviously need doing prior to fitting to my engine.
Cheers
