Page 1 of 2 12 LastLast
Results 1 to 20 of 38
Thread: Gearbox issue?
    Giles's Avatar
    Sep 2004
    Evesham, Worcestershire - nowhere near Birmingham......
    365
    Gearbox issue?
    What are the likely reasons for the car falling out of reverse and 2nd gear? Basically, when coasting (not under a lot of load) the car suddenly and randomly falls into neutral when in 2nd mainly but has done it in reverse too...
    855R manual, turquoise
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    This the 'box with the faulty bearings in it?
    Giles's Avatar
    Sep 2004
    365
    Quote Originally Posted by Pault5estate View Post
    nope - that has been taken out and this one replaced it for a total cost of £701......
    Giles's Avatar
    Sep 2004
    365
    here's the old one
  5. #5
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Dropping out of gear is not a good sign, how good was the other box?
  6. #6
    Giles's Avatar
    Sep 2004
    365
    Not good....made a hell of a racket....was told it was the layshafts (???) so i bought what i thought was a good one......
  7. #7
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Might have been worth taking a peek inside the replacement 'box before fitting, bit late now, I know.
  8. #8
    Giles's Avatar
    Sep 2004
    365
    i know what may be mentioned but I was sold that box as 'all good, no issues' so had it installed. To strip back down and use parts from both boxes and replace is gonna cost me another £702+ oil and that i am not prepared to do anymore. And I am not doing it myself. I have not the knowledge nor the tools.
    I either live with it as is......or......do i actually have a 4 letter word carved on my forehead or something........first it was a car worth £300, then an actuator that almost killed my engine, and now a gearbox that's no better than the one i removed?
  9. #9
    Giles's Avatar
    Sep 2004
    365
    Unless it is a fitting issue? It's either:
    a] fitting issue
    b] needs time to settle (as was advised to me)
    c] knackered
  10. #10
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Ouch, but I feel your pain, I also had a few gearbox problems, and, I haven't even used mine yet!
  11. The Following User Says Thank You to Volvostorm For This Useful Post:
    Giles (Wednesday 20th April 2011)
  12. #11
    Giles's Avatar
    Sep 2004
    365
    thing is, the guy who sold me the gearbox is probably gonna be livid when he sees this as a post as opposed to contacting him......but, dont know what options there are short of full refund and payment for fitting (£701)? And that aint gonna happen. It was sold as secondhand (albeit 'good, no issues'), I have no receipt and as far as he knows, it may have been fine in his car.....
    I can (and shall have to) live with it, just feel f****d over once again......no disrespect to anyone but this has cost me £3,300 so far and it still aint working and has the same issues......
    Through my own selfishness in having this effing car, i have now spent the family holiday fund on it, but that's my issue. Should have stuck with my ****ty Peugeot.
  13. #12
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    It maybe something like the gear cables need checked, check the free stuff before assuming the worse
  14. The Following User Says Thank You to Volvostorm For This Useful Post:
  15. #13
    Giles's Avatar
    Sep 2004
    365
    That's essentially what i am asking with this thread.....but the garage said if it does it in reverse, 2nd and 4th then it's the syncromesh.......i have no idea about 4th tbh as only used it for 3 days.......
    If it is the cable, then great but things dont look good so far
  16. #14
    Giles's Avatar
    Sep 2004
    365
  17. #15
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Run it around, and see what happens
  18. The Following User Says Thank You to Volvostorm For This Useful Post:
  19. #16
    stu_850t5's Avatar
    Oct 2010
    Braintree Essex
    250
    another reason why i got rid of my 850R........was just about to put the 4th gearbox in it when i thought ahhhhhhh sod it..... no more now!
    i know exactly how you feel though mate! hope things turn out ok and not too expensive for you!
    stu
    Quote Originally Posted by The Flying Moose View Post
    I have it pretty much spot on now, gargles at idle, quiet cruising and sounds like a jet on boost.
    ^^^^^^how every 850 should sound!^^^^^^
  20. The Following User Says Thank You to stu_850t5 For This Useful Post:
    Giles (Thursday 21st April 2011)
  21. #17
    Chopster's Avatar
    Jan 2010
    Aintree
    27
    Quote Originally Posted by Giles View Post
    TBH mate your garage hasn't got a clue what they're on about... I hope it was the YTS lad that came out with that useful piece of wisdom, the synco is on each gear and allows the smooth intermeshing of gears
    If you're having problems with 2nd, 4th and reverse then it's the lateral throw from the selector that's not been set up right when re fitting the box. (I'm not sure on these box's just how much adjustment there is, if I get change I'll have a look on mine later)
  22. The Following 2 Users Say Thank You to Chopster For This Useful Post:
    Giles (Thursday 21st April 2011),lance (Thursday 21st April 2011)
  23. #18
    si850r's Avatar
    Oct 2010
    redditch nr birmingham the town full of chav s
    409
    another quality installation from that company giles (i aint gonna mention who did the 'repair' on here) should of kept well away from them ....Lets just hope they have the honesty to put it right...(but after what they said about mine mate...I wouldnt hold your breath)... just hope yoo can get it sorted with no extra cost to you...
  24. The Following User Says Thank You to si850r For This Useful Post:
  25. #19
    Chopster's Avatar
    Jan 2010
    Aintree
    27
    I had a quick look under the bonnet on mine today and can't really see any adjustment on the box side, most cars have some form of adjustment for the linkages (you might have to do a bit of research on just where it is on the 850's) but did note how the linkage is attached, now it is possible that the nylon bushes that fix the linkage to the box is either worn or damaged thus allowing play or if they've forgotten to to put the horseshoe retaining clip back on or even put it in the wrong slot then it would hinder the pull movement when putting it into 2nd, 4th and reverse.
    Don't let them fob you off saying it's a faulty box... it'd deffo just a selector issue.
  26. The Following User Says Thank You to Chopster For This Useful Post:
  27. #20
    Giles's Avatar
    Sep 2004
    365
    Did 150 miles today....did not slip out once in any gear.....until i went out later tonight and it jumped out of 2nd again I am unsure it's a box or a fitting issue. The guys who did the work have done everything else brilliantly. I doubt it's a dodgy box too as I know the seller is genuine and would not have flogged it knowing...if a fitting issue i will not be impressed as I took their word it was the syncromesh.....further googling suggests syncromesh tho? And a worn linkage.......hope it's the latter
