any 1 done the fuel pump mod , av got the kit but no instructions on how to fit it etc
Which mod is that?
isn't it just a 4pole relay? original 2 pump wires to trip the relay then main wire from battery in, going to feed to pump
am usless with wires lol , is it easy enough to fit pedro
leet5r (Tuesday 29th March 2011)
what the fuel pump mod supposed to do?
t5 pete (Tuesday 29th March 2011)
I'm going to do mine, once I fit the Walbro
This can be done on anything that you want to supply more current to. The coil is another good contender, I used to wire up the headlights of my cars this way too (because I was fitting illegal 150w bulbs !) you would be amazed how much current loss you get through the standard wiring. My air-con pump clutch is also wired through a relay as the existing current wasn't enough to kick in the tired clutch.
Modifications: Nowt.....yet !
Daily driver: 855 R in Black,
Dangerous Dave (Wednesday 30th March 2011)
the fuel pump drops voltage once its under load and can run cars lean etc , the fuel pump mod just keeps the pump workin as it should
tim williams does a nice kit for them
cheers
you shouldn't need a kit, its just a relay you can pick from anywhere
but yal need a decent cable from the battety m8
I looked into this when i had my 850.
I done a few runs on full boost and i only saw a .3 drop so i dont think its a must mod unless you see that theres a big enough drop from battery to pump.
http://www.terrabear-newfoundlands.co.uk/
You always come back to what you know !!!
13.8@ 103mph fastest forum 850 in 2010 Running 286bhp(former owner)
