Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    Theories for cause of fault 850R
    The new car that I'm aquiring shortly has suffered from a frozen water system over winter, apparently it popped a core plug out of the turbo. This was replaced and the turbo checked out as being ok, car now runs fine but leaves a cloud of smoke every where it goes, apparently it doesn't over heat and runs fine, also doesn't smoke until warmed up...
    Anyone care to guess at what it could be?..apparently he's been told it could be a cracked head.
    Previous cars:
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    i had a t4 that only smoked when fully warmed up it was the turbo seal that was leaking onto the exhaust and it only smoked when the exhaust got hot
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Mmm could be but apparently he's had the turbo checked over when it popped the core plug and they said it was ok.
    Previous cars:
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    barnsley s.yorkshire
    2,138
    Either what frank has said or head gasket problems i would be very causous withh it having a freezing issue froze water can expand alot and cause warping cracking etc if you do decide to buy it only offer a price for it including a 2nd hand engine if worst case
  5. #5
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Believe me I'm getting it at a cheap enough price to warrant a new engine, just trying to decide wether to investigate or just throw a new lump in it and have done with, need transport shortly due to the 960 going so whatever I do it'll have to be quick.
    Previous cars:
  6. #6
    OH DEAR
    t5 pete's Avatar
    Jul 2008
    2,138
    First off then try a different turbo it doesnt take too long to change if that doesnt work take the head off and look for a breach on the gasket if nothing there get the head pressure tested its a case of elimantion
  7. #7
    Chopster's Avatar
    Jan 2010
    Aintree
    27
    Sorry mate but I'd have to agree to your first thought, the chances are the head or the block's cracked (classic symptoms... engine heats up then the crack opens and passes water into the combustion chambers)
    I hope I'm wrong though...
  8. #8
    Jul 2008
    Manchester (ish)
    215
    never seen an engine survive being frozen. The force that ice can exert is immense. Probably done the head, possible cracked the block. I will be suprised if you get away without having to fit a new engine.
    Have it pressure tested that will tell you everything you need to know.
  9. #9
    S70T5Chris's Avatar
    Mar 2005
    Dull Southampton!
    1,124
    I might know of a decent T5 engine down this way should you need one.
    Factory White 855R : 2.5 Bottom End : Ported & Flowed Cylinder Head : TD04 19T Turbo
    VXR Injectors : ME7 Manifold : TWR Throttle Body : Blackbeast IC : AEM Progressive WI : Ferrita 3" Downpipe
    Milltek Cat-Back : BC BR Coilovers : IPD ARB : AP Racing Brakes : M56 & Gripper LSD
  10. #10
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Cheers Chris, I'll bear it in mind.
    Previous cars:
  11. #11
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    if it is a head gasket it will boil out the expansion tank and the smoke would be white and it would smell different to oily smoke
  12. #12
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Apparently the car drives normaly even though it's smoking it's head off.
    Previous cars:
  13. #13
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by Tomcat View Post
    is it oily smoke if so could just be a leak what i had the seal was only a couple of quid, when a head gasket problem causes smoke then its usually too far gone and wont drive properly
  14. #14
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Dont know yet..
    Previous cars:
  15. #15
    your mars a welder
    Jun 2009
    sunderland
    978
    well core plugs are designed to go in situation like that tomcat , if ya unsure on what the problem is ya have to try the next weakest link which chance to be the head gasket like pete said , if its not over heatin its probs just the gasket itsself
  16. #16
    your mars a welder
    Jun 2009
    sunderland
    978
    if the blocks cracked would the water and oil not mix
  17. #17
    This status has no user
    cherry1809's Avatar
    Jul 2008
    Miles from anyone
    1,816
    To keep costs down, I'd just change the lump anyway.
    Pull the old one apart and modify it over time
    Current Chariots...
    Micra K11 'project sh*tbox'
    V70 D5 daily
    1991 Transit Recovery
  18. #18
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Tbh that's what I think I may do, the lump that's In it is fairly high mileage anyway. Just got to find a cheapish engine now but can't actualy buy anything until the payout comes through.
    Previous cars:
  19. #19
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    2,980
    Ok, cars finally landed. At first glance it looks really nice (few small dints and stone chips etc), checked oil and water, water was a litle low (no antifreeze) and oil is completely none existant. Before realising there was no oil I ran it, smoked it's head off almost imediatley and it doesn't smell like water, hoping it may just be the seals that have gone in the turbo..or failing that the valve stem seals(which would drain the oil faster?). Still sounds ok, no rattles etc, just very, very smokey.
    Aside from that everything works bar the sunroof which will go up but not back, front bumper has a large crack in it but I should be able to weld that.
    Oh, just out of interest, what colour should the roof lining be in an R?...seem to remember it being dark in the T-5R but I can't remember, this one is beige, everything else is spot on....
    Previous cars:
  20. #20
    Vikingxl's Avatar
    Mar 2005
    Reykjavic
    656
    Lime green lining
