Results 1 to 12 of 12
    dannt5's Avatar
    Dec 2004
    2
    Help with tyre probs?!
    Hi all,Does anyone elts have problems with tyres wearing very badly on the inside&outside edges(leaving the middle with 2-3mm tread left),fronts&rears in less than 3000miles? I have had the track rods,lower arms,shocks all replaced with volvo parts & its still the same.Im running 205x40x17s on my 850 t5 estate.Ive had all sorts of tyre makes,pirrelli,michelins,goodyear,fulda,bf,yokos++ + & they all do the same within 2-3000miles,the car does get used as it should be but im running out of ideas,not to mention money!! Help????
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    Silly question - but have you had the tracking done?
    Volvo ABS ECU Repair
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Its the camber alignment thats out, i take it your car came with 16" alloys from new, by adding 17" the tyres are not completely flat on the road as they are bigger and wear the edges, a decent mechanic should be able to sort it!
    <a href="<a href=http://s65.photobucket.com/albums/h225/RobertBingley/Misc/?action=view&current=Animation1.gif target=_blank>http://s65.photobucket.com/albums/h2...Animation1.gif</a>" target="_blank"><img src="<a href=http://i65.photobucket.com/albums/h225/RobertBingley/Misc/Animation1.gif target=_blank>http://i65.photobucket.com/albums/h2...Animation1.gif</a>" border="0" alt="Photobucket"></a>
    GuyD5's Avatar
    Aug 2004
    Halesowen, West Midlands
    2
    and last but not least, wear on both edges is also a classic sign of under-inflation, what pressures were/are you running the tyres at?
    Wise men talk because they have something to say; fools, because they have to say something - Plato
  5. #5
    dannt5's Avatar
    Dec 2004
    2
    Question
    Hi,the trackings spot on,ive tried a selection of pressures from 32-38psi & had the camber checked.The wheels are genuine volvo ones from a V70T5R so the fitment should be spot on.My local tyre firm tells me its nothing more than exessive speed on corners,if this is so i cant be the only person with a t5 having this prob?
  6. #6
    Justin's Avatar
    Aug 2004
    Midlands UK
    374
    Who checked the camber ?
  7. #7
    Aug 2004
    Braintree, Essex
    0
    Quote Originally Posted by dannt5
    I would say you are probably scrubbing the tyres due to over inflation and reduced grip.
    Do you carry allot of heavy loads ? if not then you are way too high on the psi.
    Spec:
    Pressures from cold
    Up to 3 persons
    Saloon: F 32 / R 29
    Estate: F 32 / R 30
    Fully laden
    Saloon: F 33 / R 36
    Estate: F 35 / R 41
    I run my 215x45x17's Saloon F32 / R29 and have no feathering problems.
    Give it a try it might help
    SAM ECU
    Custom Super 60 18T Turbo With Uprated 300/70 W/G
    Blitz Dual SBC Boost Controller
    Blue Injectors
    NGK Iridium Spark Plugs
    Custom 1 Box 3" Turbo-Back Exhaust
    TurboXS Type R-HFL
    K&N Style Cone Filter With Cold Feed
    87 Deg Stat
    Full Poly Bushed
    Custom 60mm Drop Suspension
    Strut Brace
    18" Shadow Chrome Pegs
    305mm Drilled Brembo's With Ferodo DS Pads
    6000k HID Kit
    Flat Areo Style Wipers
    See All The Pics Of SAM Here
  8. #8
    dannt5's Avatar
    Dec 2004
    2
    Hi,volvo checked the camber settings.I dont carry any loads & hardly every have more than 2 people in car.Ive ran at 32psi all round with 1 set of tyres,1set at 34psi,another at the standard settings as on the fuel flap & almost every combination i can think of but they still wear the edges.Ive tried just about every logical thing to cure it & am running out of ideas,is there anybody elts that has the same prob??
  9. #9
    Casual poster 15 years on!
    Murphy's Avatar
    Oct 2004
    Derbyshire
    100
    Has the car been involved in an accident at all ?
    My TWITTER username
  10. #10
    Markzx's Avatar
    Nov 2004
    From corner to corner
    0
    I've had this on my 94 850 T5 Estate. I was running Perrelis P6000's on 17's and all I did to stop it was inflate tyres to 40psi. They wore evenly but if you ran over a mouse you could tell what Sex it was.
    Where are my pipe and slippers Nope not behind here
    They're new Tartant zippups too
  11. #11
    dannt5's Avatar
    Dec 2004
    2
    Hi all,its never been in any kind of bump that i can tell of & i went to town on it when i was lucking to buy it.It drives/handles perfectly compaired to the last 2 t5s ive had & as well as my friends s60 t5.I did try the pressures at 40psi but it did tend to run on in bends badly & track the white lines so i changed them back after a day or so.My last 2 T5s scrubbed the edges on standard 205x50x16s but not as bad as this seems to on 17s.
  12. #12
    Dec 2004
    54
    Dan,
    Have you replaced both halves of the front suspension top mounts ? Might be worth giing me a call at volvotuning.
    Regards,
    Hamish.
