So.. I didn't use the car for 3 weeks or so. Went to start, battery flat, put on charge. Fit charged battery. Turns over, over and doesn't start.
Had a problem with one of ECU pins corroded causing similar problem a while ago. Removed ECU, sprayed dodgy pin with WD40, gave a scrape, still no joy
Check at sparkplug end, no spark. Cleaned dizzy cap, rotor arm. No spark. Checked spark from coil - none. Resistances over coil reading correctly, also being supplied 12v.
Fuel in fuel rail (checked schrader valve). Hear fuel pump operating, sounds no different to normal.
Tried 3 different keys, also activated / deactivated immobiliser. Checked all fuses in fusebox.
Have checked previous threads, nobananas mentions a relay on top right of radiator possible wiring fault causing no voltage to crank position sensor?. Cant find said relay - can only see 3 for cooling fan on top left of radiator and one in the middle for something or other.
Could anyone suggest where exactly is this relay and does anyone have any other suggestions of obvious things to check? (bearing in mind i have a very limited set of tools and knowledge)
Thanks in advance
Andy
