Results 1 to 6 of 6
    flyingbrick's Avatar
    Sep 2008
    Port sunlight , Merseyside.
    493
    Unhappy Help please. Rear wiper problem.
    Hi guys.
    Like in title. My rear wiper works but it moving very slow. Was wondering if anyone has had this problem. The front wipers sweep the screen at normal speed. Will it be a lazy motor or something. No other electrical problems with the car so am thinking it will not be the battery.
    Cheers Mark..........
    EBC DRILLED GROOVED DISCS. EBC GREEN STUFF PADS. AIR CON REMOVED. TWIN EXIT EXHAUST. BLACK MESH GRILLE.GREEN PAPER AIR FILTER. FRONT SPLITTER. POLY TOP BUSH.V70 REAR LAMPS
    The greatest trick the Devil ever pulled was convincing the world he didn't exist
    http://www.r2rc.co.uk/landing/index.htm
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    its the metal grommet going thru the glass, the different metal in the collar & on the wiper shaft corrode against each other. You need to strip it down, remove the wiper arm/shaft & grease it up
  3. The Following User Says Thank You to p fandango For This Useful Post:
    flyingbrick (Saturday 22nd January 2011)
  4. #3
    Trader
    No Longer a trader.
    Tomcat's Avatar
    Aug 2004
    Sunning it up in Chorley
    2,980
    If it's an estate then it's probably the seal that's gone. When this fails it allows water into the mechanism, the wiper shaft runs through an aluminium cradle which once wet rusts and gradualy seizes the wiper up. When mine went I had to take the mechanism appart, sand off the corrosion and apply a liberal coating of grease, or failing that just replace it.
    **Bugger......beaten to it again**
    Previous cars:
  5. The Following User Says Thank You to Tomcat For This Useful Post:
  6. #4
    Sep 2008
    493
    Thumbs up
    Well done Pedro Top man thanks very much.
    Thanks aswell Craig.......
  7. #5
    No replacement for
    displacement!
    Redbrick's Avatar
    Mar 2005
    Bristol
    35
    You'll also find the black plastic sleeve that passes through the tailgate and glass will be cracked. Get a new one from a dealer before you re-assemble it all or from experience you'll be doing it all again in a couple of weeks.
  8. The Following User Says Thank You to Redbrick For This Useful Post:
    flyingbrick (Sunday 23rd January 2011)
  9. #6
    Sep 2008
    493
    Thumbs up
    O.K. will do thanks very much..........
