A Massive thanks to Tim Williams for doing my Build!!!
Anyone who has been there , Then you know!
Massive thanks for anyone who has helped me with the spec.
The list
All new Bearing, Bolts, Seals, Oil pump and Pistons
Don Rods
3" Ferita Angled DP
Ported Cylinder Head
Kalmar Union Billeted Fly Wheel
Tim Williams Big Bore TB
Reinforced Block
Ported HLM Low Breed Turbo
S60R Exhaust Manifold
S60R Water Pump
75mm Alloy IC
Setrab Engine oil cooler
RIP Pipie work & New coolant hoses
Catch Tank (Because Engine now has oil inside it!)
Wooden Manual Knob
850 R Clutch
Gripper Diff
Uprated Offside Engine mount
Non Dog Chewed Gear box tie bar bush
Secured Brake Pipes
Oil Tight Engine
Engine bay stripped and Re painted
Water tight Non flashing 55w HID Main & Dipped
Innovate Wide band AFR
60R/Porsche Front Brakes
Team Dynamics Pro Race 1.2 17x8J Option of of 235/35
Runing Redline D4ATF in the PAS
Redline SAE 75W250 Gearbox oil
Redline 10W40 Oil in the Engine!
RBF660 Brake Fluid
Really Terrible Rattles Removed from Dash board Now strangly quite?
Still to fit:
Spa Oil Temp & Pressure Gauge
Replace "Custom to my spec" Fuel Pump
Aquamist Water Injection
470cc Injectors
70mm MAF
MTE Custom Map
Tax Disc Holder, Numberplate and rear Window sticker
Thanks Greg
