Hi to you all,
I'm a new member, with a '96 850 T5 (855) CD Estate. I have had an intermittent fault with the ABS warning light coming on and saw that another member can fix these, but I've just had the warning light (arrow) for the auto transmission come on a few days ago, then went off and has come on and gone off again since then. The car is running fine (except when the light is on - but I understand that when the light is on gear selection is restricted to 2 gears + reverse) and there do not seem to be any problems with the auto box the rest of the time (I hope). Also a few months ago the Lambda warning light came on for a short while - but car ran fine. What I want to know is - Is the ECU for the ABS the same as the Auto Transmission and would the wizard member be able to fix both problems or might it be a bad earth to the ECU's - and where are they. Hope someone can help - I love this car, but cant afford a new gearbox and ABS ECU right now. My diagnostic box is not the one next to the washer filler.
