Good to hear your back in business again Colin... we all knew you wouldnt be down long
I hope this new one brings you better fortune! Keen to see it on the dyno again after last time.
claymore (Sunday 10th March 2013)
New Update: The new block has two cracked liners, but has been shimmed and repaired by Tim Williams, and after a chat with him, he says it will be fine, so my block has one liner cracked and Tim sees no reason why I can't simply repair my block, so that will save a huge amount of work. Also, if it works I will have a 2.4 shimmed block for sale.
PIC][/SIGPIC]
aaaaaaaaaaaaaaaaaaaaaaaaa
2.3's don't split, but I was running stupid boost when mine went, so I'll rain that back in a bit when it's all back together.
PIC][/SIGPIC]
So, even if a liner splits, as long as the engine's shimmed it's fine?
I know of quite a few on t5d5 with repaired split liners, the only down side is you may have a little coolant loss, I can live with that as long as it doesn't pressurize the coolant.
PIC][/SIGPIC]
stribo (Sunday 10th March 2013)
When I did my lpt I never had a split liner ever
PIC][/SIGPIC]
PIC][/SIGPIC]
then you would have split your liners
PIC][/SIGPIC]
PIC][/SIGPIC]
When I was at college years ago we where told that in an ideal world a 1.0 litre N/A engine would produce 100 bhp, when you turbo a 1.0 litre engine in an ideal world it would produce 200 bhp, but as the internal combustion is so poor in turning air/fuel into power it would only produce about 60 bhp N/A or 120 bhp turbo`d.
So on those lines a 2.3 turbo`d engine in an ideal world produce 460 bhp.
Anything above this figure you are asking for engine failure eg, split liners.
