Results 1 to 18 of 18
    JelT5's Avatar
    Feb 2009
    1,925
    Compression/leak down test
    I'd been burning oil and getting smoke on idle for ages, so decided to get the above done today just to be on the safe side. The results were pretty good and not what I expected at all
    All 5 cylinders measured @ 11.7 on the compression test, however there can still be problems even with a result that's pretty good...
    So the real test is the leak down; could have knocked me over with a feather, worst cylinder on test scored 94% the next 96% and the remaining three all clocked 97%. So basically my engine is pretty much as it came out of the factory. Happy days!
    Still don't know why the SOB is smoking and burning oil though, so the 18T will be coming off and going for a rebuild/ freshen up very soon.
    The leak down test is well worth it if you've any doubts about your engine.
    Beer Baron
    LiamT4's Avatar
    Jan 2010
    Leicester
    1,849
    Sorry for sounding dumb but whats a leak down test?
    5 pot heart of a Volvo
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    what did they charge you for that?
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Could still be stem seats, I've just changed mine, they were hard, and one had split
  5. #5
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    glad to hear your engine's alright mate, 19t it is then lol
  6. The Following User Says Thank You to p fandango For This Useful Post:
    JelT5 (Friday 22nd October 2010)
  7. #6
    JelT5's Avatar
    Feb 2009
    1,925
    Quote Originally Posted by leighkaicraigmia View Post
    50 euro
  8. #7
    JelT5's Avatar
    Feb 2009
    1,925
    Quote Originally Posted by LiamT4 View Post
    Two gauges rated to 100psi (%); one to read the compressed air fed into the cylinder is kept at a constant 100 psi, the other to read the leakage. Cylinder/piston locked at tdc, compressed air fed in via the spark plug opening and voila you get a very accurate reading of the state of the cylinder and valve guide(s)/ valve seal(s).
    A compression test is a less accurate way of reading the engine condition.
    LINK
    HTH
  9. The Following User Says Thank You to JelT5 For This Useful Post:
    LiamT4 (Saturday 23rd October 2010)
  10. #8
    JelT5's Avatar
    Feb 2009
    1,925
    Quote Originally Posted by p fandango View Post
    Sod a 19T mate I reckon it's gotta be a rod bending Garret next lol
  11. #9
    JelT5's Avatar
    Feb 2009
    1,925
    Quote Originally Posted by Pault5estate View Post
    It's unlikely (but not impossible) as the leak down tests the valves too. I'm hoping it isn't valve related mate as I can't afford a cyl head overhaul at the mo
  12. #10
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    I knew leak down tests the valves too, but surely that's the valve seats and not the stem seals?
    Hopefully, it's nothing to bad, my head work came to £500 including a port and polish.
    What Garrett you thinking using? I'm using either a GT28 or GT30
  13. The Following User Says Thank You to Volvostorm For This Useful Post:
    JelT5 (Saturday 23rd October 2010)
  14. #11
    Oct 2010
    4
    3071r all the way, these engines can maintain stupid power with horrifically worn components, got to love em
  15. #12
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Quote Originally Posted by Martin-t5r View Post
    Yeah, mine was running 245bhp with 11thou of wear in it's bores
    Been rebored now, +0.5mm
  16. #13
    "The Instigator"
    The Flying Moose's Avatar
    Sep 2008
    Norwich, Norfolk
    2,842
    Anybody know of somewhere in the UK that can do leak/down tests? Would quite like the answer to my smoking, not serious but still frustrating. Is it something most reputable garages can do?
    Arguing is pointless....she may not be right but she's never wrong
    Tell her a remap is just having your satnav updated.....
  17. #14
    Blah Blah Blah!
    Volvostorm's Avatar
    Nov 2008
    Condover
    92
    Engine rebuilder might do it, or some tuning places?
  18. #15
    Oct 2010
    4
    I would have thought most garages should be able to perform a leak down test. Lol at Pault5estate it's crazy how they hold together any other engine would throw in the towel before then lol. Worn engine, throw a load of boost at it and it will be fine
  19. #16
    JelT5's Avatar
    Feb 2009
    1,925
    I don't know mate tbh. The guys at the garage (they run a low 9 second Chevy Nova and a 10sec GMC Syclone twin turbo) are of the opinion it's deffo turbo related...I really hope it is!
    double that and add 500 in France, sadly
    Ideally a 3071 (as Martin t5r mentioned) but I think that's going to have to be a long way in the future- funds are limited so have to get the 18t refurbed for now boohoo
  20. #17
    T5frankie's Avatar
    Apr 2006
    On the strip
    4,423
    Quote Originally Posted by JelT5 View Post
    whereabouts in france you from mate i get over quite regular as my old man has lived all over the country and now for the minute is is living in a tiny hamlet called laruscade about 30 kms nw of bordeaux, was only there a few months back, thats where i blew my clutch lol
  21. #18
    JelT5's Avatar
    Feb 2009
    1,925
    I live in Metz- quite some way from Bordeaux. Come back to the UK quite often though, but doubt I'll be back until next year some time now.
