Results 1 to 17 of 17
    230K, aiming for 300k!
    Sep 2009
    Shrewsbury
    11
    Joined the club, but problems on first run
    Just picked up my 03 V70 D5 SE, I have to say I'm very impressed. It's so comfortable, and quiet.
    Couple of minor niggles though:
    There's a noise from the dashboard area, that I thought at first was the climate control fan, but it seems to be linked to when the car is on boost. No throttle, no noise. Is this normal? It is quite noticible. Even my wife commented on it.
    Took it on it's first motorway run this morning, and I've been greeted with 'ABS service required' and 'Brake Assist Service Required' messages. This along with a rubbing noise from the nearside front when turning right, leads me to suspect there may be a problem with the braking on that wheel. (Just call me Mr. Holmes!). Could this just be an ABS sensor that's got crudded up from being stood for a couple of months?
    Either way, I'll be in touch with the dealer this morning to get them sorted, just wanted an opinon from real people.
    Oh and the steering wheel cowl seems to be rubbing and squeaking. I'll have to fettle that this weekend.
    Other than that. What a car Deceptivley quick as well.
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by JimmyBurnWorld View Post
    Welcome to the club
    Firstly, what type of noise is it, creaking, whistling, groaning???
    ABS wise, it MIGHT be that its been stood a while, have you tried STAMPING on the brakes a few times??? You could also have a slightly seized caliper due to it being stood.
    Also, check your wheel bolts, make sure they are nice and tight
    My cowl can squeak from time to time, but its only started in the cold weather. The plastics seem to get creaky and moany at this time of year.
    I guess you've got some sort of warranty, so you should be ok
    Thankyou, Goodnight....much love
    Member
    Oct 2010
    4
    hello, describe the noise on boost a bit more for us all, my car makes a loud wooosh noise when i floor it i was worried at first then was told its the turbo doing it's job! ( now i like the noise) noises do travel so a noise in the dash may be coming from the front of the car, just a thought.
    enjoy the forum and the car.
    regards tony.
    Balder than My Tyres...
    Flatout Phil's Avatar
    Aug 2009
    Leafy south London
    1,174
    You must check this thread out - it sounds REALLY similar: http://www.vpcuk.org/forums/showthre...ighlight=noise
    I would also give the dealer a list of the faults and get him to sort it all out. That's why you went to a one isn't it?
    KISS Rs
    850R manual, Rica 310, IKEA fitted bathroom, H&C running water, Jetex 2.5", pipe rack, cap stand, Forge BOV, circular wheels with full 360 degree rotation, 302mm discs, IPD front and rear anti-roll bars, numerous shiny features, sub-atomic particle accelerator, VTOL capability ...Volvo With Attitude!!!
    Also to be seen in a gold Honda CR-V these days...
    "It's really fast, and growls like a tiger!"
  5. #5
    RobbieH's Avatar
    Jul 2008
    Sunny Salford
    80
    I've had the same 'ABS service required' and 'Brake Assist Service Required' messages not long after I bought my barge. Probably a result of clogged ABS sensor ring. I "cleaned" mine with a well directed blast of water from a hose pipe . Never come back (maybe quick driving blows the dust away rather letting it build up
    Noise from the dash board area - not sure. My CCU fan can be relatively loud at times when it's being asked to cool ot heat quickly (manual mode with fan turned up). tTe other noise is the multi-tone whistle when the turbo spools up. Quite noticable at lowish speeds but gets drowned out from about 30mph upwards. Sometimes get a dump whoosh when changeing gear but only really noticable with my window down. Can't really hear it inside the cabin normally.
    Deceptively quick; wait 'til you remap it
    Don't let age define you. It's a number that's all.
    04 V70 D5 EUIII SE (MTE remap, IPD arb's, Eibach Pros, TWR custom FMIC, UR front strut brace)
  6. The Following User Says Thank You to RobbieH For This Useful Post:
    cornclose (Thursday 21st October 2010)
  7. #6
    cornclose's Avatar
    Jul 2008
    Fort Thankdale
    1,539
    Is it the engine ?
    Chris
    2010 Alfa Romeo 159 JTDm
    2001 V70 T5 SE (RICA 310)
    1997 9000 Aero (Abbotted)
    Visit my Rant
  8. #7
    Sep 2009
    Shrewsbury
    11
    Quote Originally Posted by cornclose View Post
    Is it the engine ?
    Boom Boom!
    Well, the ABS has sorted itself out. Went out, started her up again and all was ok. Dealer I brought it from was contacted at 8:30 this morning and was actually very helpfull, I just like to understand these things.
    Will look into /listen to the noise.
  9. The Following User Says Thank You to JimmyBurnWorld For This Useful Post:
  10. #8
    Sep 2009
    Shrewsbury
    11
    Well, the same faults came back on the way home tonight. Happened again at motorway speeds.
    Same again, got home, went out 10 mins later, started it up and the message 'Anti Skid Disabled' with ABS warning lamp.
    Switched off, started up again, no messages or warnings.
    I did notice towards the end of my journey, with the ABS warning on, that the ABS was cutting in during relatively normal braking.
    Seems to be ok again though.
    Thinking a 'Well Directed Jet Of Water' tomorow evening after work.
  11. #9
    RobbieH's Avatar
    Jul 2008
    Sunny Salford
    80
    Um, did you just contact the dealer or have they had the car back and checked it out. At least the codes need reading first.
  12. #10
    Sep 2009
    Shrewsbury
    11
    I only spoke to the dealer. In fairness he managed to get me booked into both a main dealer and indie specialist if I needed it.
    Only problem is that I live in my car during the week, so I didn't have time unless it was a real issue. Anyway, it appears to have cleared up properly now, without any water jets. Got the morning to have a good look over her in the light, but I'm suspecting it was just a bit of crud on a sensor. Will look into the bulkhead grommets & bungs to see if anything is adrift re: the noise.
    200 miles later and I'm liking it! 5th gear overtaking... Effortless!
  13. #11
    Sep 2009
    Shrewsbury
    11
    Small update.
    Been getting the warnings on every run recently. Bloke I brought it from got me into the main dealer to have it diagnosed and it turns out the front right ABS ring is broke. As in actually split!
    Getting it replaced under warranty.
  14. #12
    Shiny Superstar
    Back in the game!
    Wobbly Dave's Avatar
    Aug 2004
    Stunning Shropshire
    2,501
    1stly
    Shrewsbury is now my local dealership - even though I still take my car to HLM down in Bromsgrove.
    I shall do this in teenage style...
    "Next time you are in Telford, we should like totally hang out. We can go to the Mall or something like, init"
    Volvo ABS ECU Repair
  15. #13
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Small update.
    My ring has split & cracked on both sides. It was quite painful
  16. #14
    Jul 2008
    Manchester (ish)
    215
    Ellen been banging you with the strap on again Dave ?
    Its ok you can admit you like like it...... :-)
  17. #15
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    It's ok I have them both replaced LOL
  18. #16
    Dec 2004
    54
    Quote Originally Posted by Wobbly Dave View Post
    The strap on and Ellen !!!
  19. The Following User Says Thank You to hamish For This Useful Post:
    wegal (Monday 22nd November 2010)
  20. #17
    Shiny Superstar
    Back in the game!
    Aug 2004
    Stunning Shropshire
    2,501
    Quote Originally Posted by hamish View Post
    That's quite funny even for you Hamish.
