had this light come on this pm .what do i need to fix/replace to get it off again? ta!
You need the codes read. It's basically a check engine light.
If yours is a 96 car than you need a flash code reader or dealer.
If pre 96 you should have a little box near power steering and windscreen top up to read the codes.
steve855 (Sunday 26th September 2010)
Lamba sensor mate, probably got a small air leak somewhere, check all the little elbow pipes first.
If its a 96 car with the ODB socket under the dash you can make a code reader have a look here ;
http://www.volvoforums.org.uk/showthread.php?t=83897
I would read the codes first the light can mean any number of things .
Good luck with sorting it
1996 855 R
1995 855 T5
1968 Califorian Imp
