I have bought a manual boost controller about to fit it just need to know do I remove the TCV or fit the MBC inline between the TCV and MBC or as the instructions say just plug the MBC inline between the blue line going from the inlet manifold to the compressor
According to the instructions: "Find your wastegate actuator attached to the turbo, unless you are using an external wastegate. The wastegate actuator will have a vacuum line port that runs to a boost source. The boost source is usually either the turbo's compressor housing, the intercooler pipes, or the intake manifold. This vacuum line is where the manual boost controller will be installed. If there is a T fitting in the vacuum line between the boost source and the wastegate actuator, it will have a separate vacuum line that runs to the boost control solenoid. If you have the T fitting, remove the line that runs to the solenoid, but leave the solenoid plugged in."
