Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    creaking noise - steering
    Of late when I am manoeuvring and turning the steering wheel I can hear a what can only be described as a creaking noise at only this time. What could it be.
    Darren
    v70torslanda's Avatar
    Jul 2008
    Mancuniumshire
    28
    Arthritis?
    "Sgt. Butterman? Little hand says it's time to rock'n'roll!"
    "Bring the noise!"
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    WEIRDLY! Last week, my S60 felt "dry" when i moved the steering wheel. No creaking as such, just a dry feeling when moving the wheel. When i stopped, i released the power steering res, and it let off a hiss, so im guessing ive got a bit of air in there. After i did this, its been ok, but its started to creap back, so Im going to keep the car running with the cap off and give it some lock to lock to ease it off.
    If yours isnt the same, it could be top mounts or bottom ball joints???
    Thankyou, Goodnight....much love
    Cubes's Avatar
    Jul 2008
    Middlesbrough
    1
    Is it every time you turn the wheel, or just at/near full lock? If it's the latter I would check your stearing stops first. They're just behind the track rod and are a small pad (mine are blue). Turn your wheel to full lock to get to them. They'll just need greasing up with copperslip of something similar. Mine need doing every 2/3 months.
    Meet Abby, an elegant lady... Still, very willing to go topless in public. All I gotta do is push the right buttons...
  5. #5
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by Cubes View Post
    Yip, thick white grease on your lock stops if its only on full lock They'll probably be yellow plastic looking pads on the back of your wishbones
  6. #6
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    The noise is apparent at any steering angle in either direction.
    Darren
  7. #7
    has no status...
    richiemat's Avatar
    Jul 2008
    The South!
    170
    Quote Originally Posted by Libra View Post
    mine was the same last year, the top mounts had failed on mine.
    2001 V70 T5 - Auto, Dark Anthracite Comets, Volvo Window blinds, ITG Panel filter, Strut bar solid bushes with powerflex top mount
    Must update my sigpic ...the S60 lemon went a while ago.
  8. #8
    Nov 2009
    0
    Creaking
    Obvious, but have you checked the Power steering fluid level? Low fluid will cause a sound like creaking, common fault is at the hose clip at the bottom of the reservoir. I only use Volvo fluid to top up to avoid any internal seal problems.
  9. #9
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    Quote Originally Posted by richiemat View Post
    Easy job to replace??? How much???
  10. #10
    Jul 2008
    Mancuniumshire
    28
    Thumbs up
    Quote Originally Posted by Liddo View Post
    Spring compressors reqd.
    Leave them till you change your wishbones, it will save you having to dismantle everything twice.
    luv'n'stuff
    John
    "Bring the noise!"
  11. #11
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    Quote Originally Posted by mds View Post
    I have had the power steering reservoir changed last year under warranty.
    Also I would like to add that the noise is only appant at slow parking speeds.
    Darren
  12. #12
    has no status...
    richiemat's Avatar
    Jul 2008
    The South!
    170
    I didnt do it I also had wishbones and shocks at the same time £££££
    Quote Originally Posted by v70torslanda View Post
    luv'n'stuff
    John
    Wise words
    My resevoir has been changed twice now as they were leaking which i think is a common fault. I thought the creaking on mine was maybe a steering rack issue but it was the top mounts (i understand there are 2 on each side) one rubber mount and one bearing race and it was the rubber one that had failed.
    Good luck in identigying the problem Darren.
  13. #13
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    An noise update. I have come home and got my dad to listen to the noise which is more of a creaking click noise ONLY when turning the steering wheel to the right from lock to lock. It does not creak going the other way.
    Darren
  14. #14
    Member
    maceastern's Avatar
    Jun 2009
    county durham
    8
    leave the car in neutral rev your engine to 3000 rpm hold it there and turn your wheel full lock to full lock if noise goes its a fluid pressure problem if it doesnt its the top mounts hope this helps mac
  15. #15
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    Quote Originally Posted by maceastern View Post
    I will try that when I get home tonight. Thanks
    Darren
  16. The Following User Says Thank You to Libra For This Useful Post:
    dave stew (Thursday 9th September 2010)
  17. #16
    Liddo's Avatar
    Oct 2005
    Skelmersdale, Lancs
    341
    I did this the other day, and it seems to have cured my "dryness"
    Cheers
  18. #17
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    Well I tried this and it did not work. I have now booked my car in at volvo for them to have a look at next week, plus a few other problems I have which I have been saving
    Darren
  19. #18
    straight5
    Guest
    Let us know what this turns out to be please, as I have similar issues.
  20. #19
    Libra's Avatar
    May 2009
    Bedfordshire
    20
    I took the car in last night as I could not drop the car off in the morning. Anyway I get a phone call to tell me what they have found. I have boiled the brake fluid that is probably because VOLVO only state that DOT 4 when in realy it SHOULD have DOT 5.1. I am having that replaced.
    Now the creaking noise apparently is the top mounts and also they say that the sub frame needs replaceing as it is bent/dented!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! They are going to let me know when I pick the car up this evening how much these parts are before I go ahead with these items.
    Darren
  21. #20
    Jul 2008
    Mancuniumshire
    28
    Wow! What did you hit?
    Make sure the dealer is replacing the subframe because it is an alignment or safety issue and not just because it has been marked on a speed hump.
    That's going to cost £LOTS! Commiserations . . .
    "Bring the noise!"
