Results 1 to 8 of 8
    Member
    Ninja Muppet
    Tribble's Avatar
    Sep 2006
    Glencoe. Scotland
    4
    Question s60 dash display problem
    Hi
    My old mans 52 plate s60 illuminated dash lights have all gone off. The clock also seems to reset itself.
    any ideas ???
    a 19t just isn't laggy enough
    p fandango's Avatar
    Aug 2004
    4,216
    sounds like the start of the famous DIM failure (Drivers Information Module), not sure if its a soldering issue or the circuit board breaking up but its a well known problem with S60's. Alsorts of weird & wonderfull stuff normally happens to the dials, my old mans currently has the clock counting backwards, no indicator or full beam dash warning & a couple of other little things
    these LINK can fix it if you send it away, new dials will cost about £700 from Volvo
    Member
    Ninja Muppet
    Tribble's Avatar
    Sep 2006
    Glencoe. Scotland
    4
    Quick reply
    I was just reading up on DIM failure and have looked a bba site.
    Just need to get a quote and see how easy it is to remove display
    Just found out that Cruise and Main beam isn't working but I kinda like the backwards clock issue !!!
    v70torslanda's Avatar
    Jul 2008
    Mancuniumshire
    28
    A member on here got it done for 99 quid plus VAT!
    To remove the clocks: Pull the steering wheel out and down as far as it will adjust. Grip the surround for the clocks under the dash hood and pull down and back - it should just unclip. Undo the TX screws that hold the clocks in place and remove.
    Remember to disconnect the battery before removing the clocks and don't switch anything on until you've refitted it all!
    "Sgt. Butterman? Little hand says it's time to rock'n'roll!"
    "Bring the noise!"
  5. #5
    p fandango's Avatar
    Aug 2004
    4,216
    Quote Originally Posted by Tribble View Post
    we were worried what it was going to do when i reached 00:00 the first time it happened lol
  6. #6
    Member
    Ninja Muppet
    Tribble's Avatar
    Sep 2006
    Glencoe. Scotland
    4
    2 mins to remove instrument panel without breaking any plastic tabs !!!
    Good guide found here : http://www.ipdusa.com/uploads/sku_files/6699_INST.PDF
    Just gotta send it off tomorrow
    Damm it all went too easy
    I disconnected the battery in the boot and then closed it.
    How do you open the boot without power ?
  7. #7
    Miserable old goat !
    S60-MBS's Avatar
    May 2006
    204
    Member on VOC got it done for £35 by TV repair shop,might be worth a try in your local area.
  8. #8
    ...here we go again...
    LeeT5's Avatar
    Oct 2004
    Kent
    1,075
    Thumbs up
    Great find!! They also remanufacture the dreaded ETM. Excellent!!
